It is currently Mon May 04, 2026 2:36 pm
 Post subject: diff Questions????
PostPosted: Mon Apr 09, 2007 7:58 pm
Ok,I have decided that I am going to order a locker for my 265.Having checked most of the feedback,I have settled on the truetrac.These apparently split at 3.54 and down,and 3.73 and up,now I have a 3.54 diff which takes a 912a584 I came across a post on Dave Bartons site,about the 588 fitting in a 3.31,rather better than the "right" part#.Before I order which should I go with?While checking out pricing,the 584 is not listed as a rear option,does this mean that it is not high preload,like the 588?What other stuff should be replaced at the same time?,Any help would be appreciated.
PostPosted: Mon Apr 09, 2007 9:07 pm
The Volvo diff takes the same unit, regardless of ratio. I believe it's the 588. The post on Dave Barton's site might've been from Matt as he tried the other diff in a 3.31 and it didn't fit.
PostPosted: Tue Apr 10, 2007 12:17 am
the 588 is the new part number. It used to be the 411 part number, apparently the 588 one is stronger, 3 gear instead of 2...something like that. Both are still high pre-load.
The 584 one didn't have the correct spacing if I remember right.
