It is currently Fri Mar 20, 2026 6:43 am
 Post subject: Supercharged redblock v2
PostPosted: Wed Sep 30, 2009 10:12 pm
since i started putting everything together the old way and started to VERY quickly run out of room i had to come up with something else...
this is it so far. i'm totally unsure of how to make sure it's straight to the face of the crank pulley though, any ideas how i could measure that?
After i friggered the clearances with the first iteration.
As well, you can see i'm learning to MIG
i realize the bead is high because i can't get enough current into the 1/4" thick angle iron to get good penetration, but any comments would be appreciated.
 Post subject: Re: Supercharged redblock v2
PostPosted: Thu Oct 01, 2009 7:25 am
Measuring squareness is pretty simple - you need a square surface (block) and a straightedge, and a little bit of measuring skill. That intake manifold is NOT square to the block, incidentally...
Your bracketry is going to need to be way stronger than what you've got, though! There will be several hundred pounds of force on the snout of that SC, and it'll tear everything apart if you mount it the way it looks like you're going. You might want to try a shorter M62 snout on there if you can - I believe it's shorter anyway, and I believe it'll fit, but that's just a guess - it'll put less torque on your mounts and will give you a bit more flexibility in where you position it.
PostPosted: Thu Oct 01, 2009 9:37 am
yeah, the way it's mounted right now is just to get it lined up/squared so that i can build the bracketry and beef it all up it's purely just a way to line it all up for the time being. AFAIK the m62 snout will not fit on these blowers, unfortunately, nor will the ford snout, which is shorter.
i'm thinking right now would be a good quality square off the block and then measuring each edge of the pulley and adjusting the bolt holes until it is square, but the problem i'm forseeing is the resolution of the measurements, in being that it would be easy to have a few degrees of misalignment that would knacker the whole setup by measuring to the edges of the pulley as they are rather narrow compared to the length of the blower.
PostPosted: Thu Oct 01, 2009 5:18 pm
The snout is sooo far out, seems like you would have some interference with the rad and everything
PostPosted: Thu Oct 01, 2009 5:55 pm
What everyone else has said with respect to the snout etc. The weld is a little high - but how's the penetration? If I was doing it, I would turn the heat down and go slower - this is how you control the bead shape and get good penetration. You can't force heat into the parent material (ie big heat, fast wire feed) if you only have light gauge stuff and small distances to cover. Remember, the weld puddle is like stirring a pot of metal - penetration results when there is a fusion between the filler and the parent material (it isn't glue).
When working with angle iron (of dubious composition usually) I would bevel the edges and give yourself some weld prep area. You'll still fill it with a single pass, but it will be a much better weld. Totally different technique to doing tube. And I'm with Matt - 1/8 wall angle iron isn't near strong enough - twice that would be fine. You can cut or drill holes in thicker plate to reduce weight (you know this of course).
Oh, and this is a wicked project. I've got an M60 and Laminova IC parts in the basement parts stash...nothing to run them on just yet.
PostPosted: Thu Oct 01, 2009 6:35 pm
heh, you guys gotta realize how far out the crank pulley sits in respect to the seal housing face, it'll look better when i mock up for a pulley.
got it jigged up straight to the block today, took a high quality square and a feeler gauge, so every level surface of the front of the block i stuck the square to with welding magnets, made sure it was perpendicular to the pulley and then used a feeler gauge to find the misalignment, now i can't even get the 0.001" one inbetween either on about 120º of pulley sweep on the blower so i SHOULD be good to go now! just gotta figure out how to make the strongest bracket I can. I'm a tad surprised just HOW far the whole blower tilted, i had to clearance the plate, and now it just touches the starter (will get cut back when it's time for bracketry)
Craig, i tried that and got even less penetration, i'm getting about 70% of the way through the two pieces when i cut it apart, so if i weld from each side it should be okay. still learning to dial in the wire speed though, never realized how easy it was to MIG, now just to refine the skills a bit more!
oh, and fyi, it's 1/4" x 3/4" wing angle. i'm going to try and figure out a plate that'll bolt to the accessory mount that i could cut with the torch and give some real strength to it some 3/8" solid plate had ought' to do the trick.
PostPosted: Thu Oct 01, 2009 8:11 pm
Go slower...it's a feel thing, so once you've done it, you'll never forget. Remember a weld that is going well sounds like frying bacon. I think you're moving to fast...how well can you see the weld puddle? What helmet are you using - for general MIG work, I use a #9 shade so I can see well. Also, get in a comfortable seated position and you'll be fine.
PostPosted: Thu Oct 01, 2009 8:36 pm
i've been using an 11, and you're right, i've been having trouble seeing the puddle. i turned down the wire speed a bit and closed up the gap and had the one weld i did tonight go well (as well as using a little bit wider zig-zag pattern)
i'm probably going to try bevelling the edges here.
as far as the strength thing goes, i'm going to brace each corner with a 1/8" x 2" piece of flat stock between the corners of the angle iron, i just ran some rough calculations and the maximum load at some points on the bracket could exceed 600lbs in tension and 450lbs or so in compression :S
PostPosted: Fri Oct 02, 2009 8:06 am
No zig-zag, that just gets rid of the heat. The only time I stitch is when I'm either welding vertically or if I've got to lay in a fillet on a T joint. I wouldn't weave on a little butt joint like that.
PostPosted: Fri Oct 02, 2009 5:00 pm
tried a temp setting down and about half the wire feed, a lot cleaner, tinier bead, but not nearly as good of penetration, turned it back up to max, tried some bevel and took it nice and slow, cut the wire speed a bit and moved closer and it seems to be laying a lot flatter with visible penetration on the other side. still the bead is a bit wobbly and uneven, but i think that'll come with practise. now, for mounting points on this blower...
so far i'll be using the 5 holes for the stock accessory bracket, the two random holes off the block nearish the starter, the and the cover of the oil pump drive. however, there are two holes up high right under the deck on the b230 in the middle of the head area that aren't on the b21 motors.... can anyone tell me if these are on all b230's/b23/what?
PostPosted: Fri Oct 02, 2009 10:48 pm
just a few more pics for those who voiced concern over the snouth length/location...
PostPosted: Sat Oct 03, 2009 9:11 am
Ok, one last welding tip, then I'm going to shut-up and let you get on with it. I'm hoping you're not using flux core on this...right? I would lay some nice filets (welds not fish) in on the backsides of the brackets. Looking at the picture, I'm afraid your welds may be cold - I don't see a head affected zone on the back side of the angle iron that is facing the front of the engine. You should see a discolouration of the mill scale when you've welded this sort of thing.
So, using the same technique, weld up a coupon out of some scrap and cut it apart across the weld. Evaluate not only the depth of penetration but the quality of the weld in general. It will be pretty obvious if the weld is just sitting on the surface or is married to the parent material.
One last little thing...when working with angle iron or any other steel - especially hot rolled anything, it is vital to get the mill scale OFF of the weld area. Grind until you have shiny steel all around the weld area to about 1 cm away from the weld joint. No need to introduce odd metallurgy into the weld process - there's enough of that going on anyway.
I noticed that you hadn't done this on the back side of the bracket. Sure it's magnetic and will produce an arc...but if this thing comes apart under load, it may not be pretty - and it may be just fine forever. If you clean it off and check your weld carefully, "just fine forever" has a much higher probability.
PostPosted: Sat Oct 03, 2009 10:42 am
yeah, you're right, i'm not getting nearly enough heat into this thing with the little mig. I am using shielded wire, but am still figuring out this whole thing.
It's about this point i'm considering finishing the 220v wiring in the garage and hooking up this old beastly transformer type stick welder to get'er done.
I'll weld up a coupon and cut it apart for you guys today to get some more critique and see if i need more power.
PostPosted: Sat Oct 03, 2009 12:09 pm
here's a quick one, cut just off the centreline of the angle iron, single very slight bevel, one pass.
normally i've got a bevel and a pass on each side...
as you can see i'm only about 40% of the way in in the thickest part, so maybe a wider bevel in that area?
and pardon my ignorance, but i'm not familiar with what a "fish" weld is...
can you enlighten me?
Regardless, i think with a pass on each side and a bit healtheir bevel i can get some welds that i'd be happy with out of this.
PostPosted: Sat Oct 03, 2009 6:22 pm
Eric,
Those are COLD as hell. I dashed out the the garage and did up a coupon for you so you can see what I'm talking about (between periods of the hockey game - now that's dedication). Let's review - I'm working with a 120V Deca 135A machine - 8 out of 10 for wire speed, High 2 heat and 0.035" wire with Blue Shield gas.
These are on 3/8 plate steel.
Top of the bead
Back - showing no full penetration, more on this later.
Start - note that the penetration is shallow as there is no heat in the metal when you start welding. I'm still 1/2 way through. Also note there is no way to see where my weld starts and the metal begins - these are fused.
This is the end of the pass...not quite 100% but 99.9 will do for this weld. No way to tell where the bead is, also note the bead shape - flat without excess wire.
This is a fillet weld. You have to weave to get this shape - the idea is to fill the corner.
Cross section. Note the consistency of the weld as you look along it's length.
Heat affected zone - easy to see on the fillet, harder to see through the rust on the butt weld.
Make them look like this and you're golden.
