It is currently Fri Mar 20, 2026 5:37 pm
 Post subject: Not a volvo but I have to ask
PostPosted: Mon Aug 20, 2007 10:28 pm
A friend of mine drives a chevy s10. poor bugger. and he still thinks he's got the superior vehicle. anyways, he's having some abs related problems. Had the code read, and it said that he needed a new ABS module thingy whatever. so he gets one puts it in, resets the code.
He's now furious he's still got no abs. Apparantly though, it's not throwing any codes.
anyone know of any similar problems what it may be?
PostPosted: Mon Aug 20, 2007 10:44 pm
no codes and no abs? Thats not a good thing...
how does he know he doesn't have abs (stupid question but I have to ask)
PostPosted: Mon Aug 20, 2007 10:45 pm
i'm gonna assume he tried to brake and locked it up again.
PostPosted: Tue Aug 21, 2007 1:01 am
check wheel sensors, they generally throw a code though. Thats about it those, check connectors and stuff too
PostPosted: Tue Aug 21, 2007 9:55 am
Exactly right. Most people plug in the code reader and immediately think it will tell them exactly what is wrong. A code will only be set when a fault is detected that is outside of preset variables, this could be caused by a faulty sensor or control unit, but it is usually a bad connection, poor ground, or broken wire. A code reader is a great tool to find the area or circuit where the problem exists, then use common sense and some basic diagnostics to eliminate or locate easy and inexpensive problems before you spend big bucks on modules and sensors
GM did have some problems with the ABS units on their full size pick-up's, I am not sure if this is also a problem with their other lines. If, when doing a brake job you just compress the front caliper pistons the brake pedal will become very low and the ABS will stop working. GM is aware of the problem but does not offer any repairs. Bleeding and/or flushing the system will not remedy the problem. The only way to safely replace front brakes on a GM is to open the caliper bleeders and collapse the pistons by bleeding the excess fluid out of the system. It is believed that contaminates in the fluid cause sticking and leaks within the servo and ABS valve bodies.
PostPosted: Tue Aug 21, 2007 3:12 pm
Ian, you are so hardcore! :shock:
PostPosted: Tue Aug 21, 2007 5:50 pm
GM does have some problems with the ABS units on pretty much any full size pick-up, GM is aware of the problem but does not offer any repairs.
fixed! :P
(damn company trucks)
PostPosted: Tue Aug 21, 2007 8:48 pm
fixed! :P
You know what I speak of ... right Vik.
Actually GM does have a fix, they are making the truck floor boards lower to allow more pedal travel :roll:
PostPosted: Wed Aug 22, 2007 12:57 pm
why don't they just remove them all together and go flinstone style!!!
I like GM trucks a lot, but only while around town, or say, gravel roads like south of Calgary, rancher's roads...they can cope with that stuff okay, but hell anywhere north of red deer in the bush...terrible
