It is currently Thu Mar 19, 2026 9:25 pm
 Post subject: what springs to get?
PostPosted: Fri Feb 17, 2006 10:16 am
Rally Car
Phase one suspension upgrades
bilsteins
25mm sways
poly bushings (replacing as needed)
springs??????
Do you guys think stock volvo springs or volvo overload springs are the way to go. I know neither are ideal but the plan is to get a few races under our belts and then go from there.
Are the overloads going to be too stiff and pummel the heck out of the driver????? My thought is that at high speed on rough terrain stiff springs are the way to go with a good set of dampers (ie bilsteins). Or are the springs going to be too stiff and not absorb enough and esentially limit usable travel???
Are the bilsteins valved to work with overloads or only stock???
Opinions????? Has any
 Post subject: Re: what springs to get?
PostPosted: Fri Feb 17, 2006 1:13 pm
Rally Racing in general will pumel the driver/navigator...lol there's my opinion
on my old 700 i only had the TME springs, with stock shocks...they didn't seem "too" stiff at all...
but for which springs would be the best i do not know...sorry
PostPosted: Mon Feb 20, 2006 3:09 am
check out http://stockcarproducts.com/springs.htm
just find out what your front spring dimensions are for the front and there you go, good cheap springs. I bought rears from them and will be putting them on the 242.
