It is currently Tue May 05, 2026 4:10 pm
PostPosted: Wed Nov 28, 2007 1:29 am
atmospheric pressure sensor.
Think I can find the part listing on vida? i've spent an hour looking for it and no luck. I have no clue.
PostPosted: Wed Nov 28, 2007 9:11 am
lol. possessed. that's all I will say of my car as of late.
PostPosted: Wed Nov 28, 2007 2:35 pm
well it is an "intermittant" fault...
PostPosted: Wed Nov 28, 2007 3:47 pm
Andy, try P/N 1275342
PostPosted: Wed Nov 28, 2007 8:12 pm
Ian....you nerd ;) how do you know the part numbers??? did the c70 pull that trick on you ever?
PostPosted: Thu Nov 29, 2007 9:29 am
Nope, mine runs great 8)
Just a little Net surfing and presto :roll:
The problem is common and the part is also known as a Baro sensor
PostPosted: Thu Nov 29, 2007 9:48 am
well, through the insanity of my beast, you will know what to expect when you get the c70 up near my milage ;)
PostPosted: Thu Nov 29, 2007 1:43 pm
Yes, I have that advantage.
Although I replaced my thermostat and engine coolant sensor, since then the car has been running much better, gas mileage and power are way up, and the heater works .... yay
Just my evap purge valve sticks occasionally
PostPosted: Fri Nov 30, 2007 12:34 am
oh, i wonder something....
when you have the hot air going, do you find that in the middle two front vents, you get COLD air for some reason? I think this only happens when its kinda inbetween some "where the air should go" settings....i dunno, my heater thing is perma-set on the windshield heat but over one notch to the right, so i'm not runnign the AC and I don't have to have the air coming in from outside (I drive by a REALLY SMELLY thing off blackfoot every day, I'd rather not inhale its pungent fumes)
PostPosted: Fri Nov 30, 2007 12:36 am
oh yes, and by the way, the whoring out of myself to cover car related expenses is back in action....any takers? VIK you're apparantly the only one who can afford me....lol ;)
PostPosted: Fri Nov 30, 2007 7:29 am
OK, I am going to sound like your father now! :lol:
"Read the owner's manual!"
The center vents have 2 dials to the left of them, the left dial which pictures a person in the seat is an "air mix" control which allows fresh air in when the heater is on. Rotate the dial on that control UP and it will close off the fresh air and only allow warm air through the vents.
