It is currently Tue May 05, 2026 5:09 pm
 Post subject: Low exhaust
PostPosted: Mon Feb 25, 2008 10:05 pm
My exhaust line is really low under the car. When I look from the side, you can see above the exhaust. The back is fine, front too. it's under the seats. Is there anyplace where I could be missing a bolt or where I could tie it?
And no Raz, I won't cut it! :wink:
PostPosted: Mon Feb 25, 2008 10:26 pm
do what someone did somehow with mine somewhere along the line...tie it up with a rag.
PostPosted: Thu Feb 28, 2008 8:05 pm
Good advice there Steph. While you're at it, put some flammable material on the rag so if it doesn't light on fire on its own, it'll have some help... :roll:
PostPosted: Thu Feb 28, 2008 8:42 pm
lol dale, i'm gonna have to point it out to you next time ;)
I don't know...it might not be a rag...anytime I've had the car up i've been looking at other parts...but it sure as heck looks like one looking back at it ;)
PostPosted: Thu Feb 28, 2008 9:18 pm
Hum... What's a rag? :oops:
PostPosted: Thu Feb 28, 2008 11:05 pm
A piece of cloth...
PostPosted: Fri Feb 29, 2008 9:31 am
And by piece of cloth - Dale really means you're probably missing a rubber hanger. If they are missing and your system is not fully welded, then things can rotate over time. If your exhaust was once tucked up neatly, then it will go back with a quick trip under the car to see what's missing or a visit to your local exhaust shop.
PostPosted: Fri Feb 29, 2008 6:07 pm
It's a OEM line installed in a dealer before I left for Alberta. It have a lifetime warranty. Should I wait until it breaks to get a new one?
PostPosted: Fri Feb 29, 2008 9:22 pm
Get a full 3" exhaust, with 3" downpipe :D You could wind up getting even better fuel economy!!
PostPosted: Fri Feb 29, 2008 9:29 pm
Wouldn't fixing it before it breaks make more sense?
PostPosted: Fri Feb 29, 2008 10:37 pm
The muffler is rusting and about to open, and both muffler AND installation was underwarranty. If it's falling, it's not because they install it correctly. But they won't change it until it fall apart... So, my seat will probably fall through the floor before they change it.
