It is currently Sun May 03, 2026 11:50 pm
PostPosted: Fri Oct 17, 2008 7:05 am
Shoulda just towed it down to my work. We gots booster cables... :)
PostPosted: Fri Oct 17, 2008 8:10 am
I have booster cables, the impound lot has booster cables. Car just wouldn't boost. Wierd.
Plus, Magnum is about 100m closer than your work:P
PostPosted: Fri Oct 17, 2008 6:29 pm
Yeah...saw it sitting on the street this morning on my way to work. You're sure it was in park? :?
PostPosted: Fri Oct 17, 2008 8:27 pm
went to get him and battery dead (i think). Couldn't jump start. The clock works, and the temp gauge would go to half, but no lights, no power locks, nuttin. So paid more to have them tow it from the compound over to magnum...fack.
Sounds suspicious. Temp gauge at half, with a cold engine? Clock works but no lights or locks? You sure they didn't tow it away after an electrical fire?
PostPosted: Fri Oct 17, 2008 10:00 pm
apparently the guys at magnum jumped it just fine, so must be the impounds equipment...
PostPosted: Fri Oct 17, 2008 10:19 pm
:shock:
At least, you got it back!
PostPosted: Sun Oct 19, 2008 12:08 pm
So not stolen, just towed away by the City ? How come ?
Glad to hear you got it back. That must be a relief, eh ?
PostPosted: Sun Oct 19, 2008 7:03 pm
Normal for a late model car to do this when you run them down enough. Its sort of akin to the speedo/tacho jumping on a later 240 when the battery is low enough. I'm not sure what sort of noise or potential difference shows up that wouldn't otherwise that causes that, but it doesn't worry me anymore after seeing a ton of cars doing it with weak batteries and a weak boost...maybe the jumper cables arc to their contacts a bit or something causing there to be a slight alternating current??
[unrelated jumpstart horror story]
At least it isn't like jumpstarting a Bowel Movement Wonder (BMW). The hood blankets conduct electricity on those I found out the hard way. Compound this with the fact that the hood shocks like to deflate all at once and make the hood fall on your nice positive lead attached where the battery isn't, the long lead to the battery is unfused, the miserable things like to leak out of the cam cover onto the hood blacket and the electronic ninnies in those things draw about 20 amps continuously with the key on. Makes for a large fire in the split second you turn your back and the hood slams...never doing that again. Sadly, customers/bosses don't like it when you do the right thing and let the car burn to the ground and you end up with a very burnt hand saving a car you hate. At the same time, you can make a ton of money off those miserable things and the owners are usually tools, so fleece away and go on vacation I say! [/unrelated jumpstart horror story]
Glad you got your car back, Athal.
PostPosted: Fri Oct 24, 2008 1:17 pm
@#(*$*(@!! city wide charged me ONE HUNDRED AND FIFTEEN dollars to tow it from the goddam impound 200m to Magnum.
How pissed am I right now? Don't ask.
Plus, on top of the rad and water pump that I already knew I needed, Darth needs ball joints, tie rod ends and front brake lines, so now I'm in for almost $500 my cost in parts. I'm getting them to do some of the work (incl. alignment), since I just don't have the time or space right now, and I still have to do some work on the 242 to get it ready for winter.
w00t. not.
PostPosted: Fri Oct 24, 2008 1:29 pm
How about I just come pick up Darth to save you all the trouble? :D
