It is currently Sat Mar 14, 2026 8:23 pm
 Post subject: +t Progress
PostPosted: Tue Jan 06, 2009 3:14 pm
well i got my package from Ian Haan (volvo940tuner)
it had half the stuff i needed :( not to mention it took FOREVER to arrive. but at least i can get more things done on the wagon.
also started molding the buttcheek sub-box. pics in a little while
anybody got a LH 2.2 001 ign ecu, turbo fuel rail and over type fpr or an oil pressure sender laying around? :?
not too impressed, but what can you do?
 Post subject: Re: +t Progress
PostPosted: Tue Jan 06, 2009 5:13 pm
A PM and some feedback on Tbrix would be in order. Last time I was at the Calgary PYP there was an intact 740 turbo there...probably been crushed by now, but they are there all the time.
PostPosted: Tue Jan 06, 2009 6:29 pm
That 740 was actually a '90, so it had all LH2.4 stuff. Not that it matters anymore, because it's gone, but Craig's right: they show up all the time. You have to be pretty early to get the computers, though.
I still have that chipped one.
PostPosted: Tue Jan 06, 2009 7:08 pm
WHOO, it runs, and drives. and most of all boosts.
aside from a slight oil leak which i fixed, and the radiator pissing fluid (anybody have a good one thats not rusty?) it goes pretty good, nice turbo sound :D
yeah i need the ignition box, not the ecu sorry. and i pm'ed him, so hopefully we can sort it all out.
pics tomorrow...
PostPosted: Tue Jan 06, 2009 7:50 pm
paperjam wrote:
yeah i need the ignition box, not the ecu sorry. and i pm'ed him, so hopefully we can sort it all out..
Good to hear it is working out
I think it is a good idea to talk with the seller first like you did, give them a chance to make things right.
PostPosted: Tue Jan 06, 2009 10:49 pm
yeah, put a smile on my face. it needs more boost now 8)
Ian pm'ed me back, saying that he understood. and asked what i meant by the ignition box. Am i wrong in thinking that there are two boxes required? or what?
lol, this sounds noobish but... (It is noobish, i just dont want to admit it)
Is the ignition box the same as the Ezk? sigh, im confused
PostPosted: Tue Jan 06, 2009 11:23 pm
Stateside, the 240 uses the horrible mopar "shake and bake" ignition brain as it is famously nicknamed bracketed to the washer tank in N/A cars with LH1.0/2.0/2.2. Only with LH2.4 or 3.1 did they get around to making a nice wiring harness for both the spark and fuel and put both computers in the cabin and also gave it EZK at that time.
I personally prefer bosch breakerless to EZK and use it with LH2.2 with no issues. I also am lazy and hate extricating the wiring and LH2.2 EZK turbo box from 7 series cars...almost as much as I hate earlier 80s 7 series cars, but that particular thing is just a drop in the bucket of hatred. I've also had to work on hackjob 240 rats nest wiring on cars that are LH/EZK converted and love making fun of people who are still slower and less fuel efficient than my turbo k-jet car is with OE wiring or my LH car is with OE updated wiring and still spent more time and money to wind up with a car that us a mess.
PostPosted: Fri Jan 09, 2009 2:05 pm
well $160 later i have a brand new rad in.
just have to install my rear window/ hatch and ill be on the road
pics tonight!
PostPosted: Sat Jan 10, 2009 1:30 am
So here are some pics.
Treasure!
ive had some trouble with the car when it comes under boost. if i just lightly hold the pedal down, the turbo operates normally, smooth acceleration (aside from M cam fallout). but when i mash it a little bit (only after a shift) it hesitates a little sometimes. not always, but usually after a shift under WOT. Its at the stock 7psi
I haven't installed the green tops/turbo Fpr yet, or either of the computers (cause im waiting for missing parts)
i could also hear the fuel pump loudly while the car was idling. Connections? probably. opinions?
to to cap, i can boost hard in first (or whatever i pull in) and after a shift to WOT i get hesitation and bucking.
PostPosted: Sat Jan 10, 2009 4:56 am
starving for fuel or misfire..
green tops arn't going to solve your problem.
Bert & Jacks Auto Service
129 17th ave S.E
228-7078
Paul
PostPosted: Sat Jan 10, 2009 6:50 am
Check your primary fuel pump (pre-pump in the tank). take off the gas cap and listen is the easiest. This will cause the hesitation symptom and the higher noise from the main pump.
PostPosted: Sat Jan 10, 2009 11:12 am
Hmm, how about non-turbo fuel and ignition set up trying to handle boost? (Another way of agreeing with Paul)
Trying to put a rod through your block already?
PostPosted: Sat Jan 10, 2009 2:00 pm
:lol:, go fast yes, blow up, not so much
Ive read on tb that the stock injectors and computers will handle stock boost just fine. (the article is called "the bare bones +t") it seems to do that just fine. i don't hear any sort of ping sounds (is that not what happens when it starves of fuel?).
I will replace the pre-pump for sure, just for security reasons. Fcp has the pump for about $50. Or should I just mod it for a walbro 255lph and eliminate the pre/main pump setup? maybe give myself a little overhead for when im ready to turn up the boost?
I don't really want to do this with junkyard parts, I want to do this cheaply, but spending $100 is cheaper than a whole new engine...
if anybody has a good used setup that they would be willing to part with, I would take it. oh and im still looking for and oil pressure sender too.
thanks for all the help too guys :)
PostPosted: Sat Jan 10, 2009 10:12 pm
no sounds
all I hear is the pump under the car...
ordered a new in-tank unit, Fcp only wanted 35 for it.
PostPosted: Sun Jan 11, 2009 7:14 am
no sounds
Not so fast!!!
First check the wiring to the pump. A common problem is the ground on the sending unit flang (outside of the tank) corrodes. Also I have seen the feed wire break in the same location. So the first thing I would do is check that wiring.... but in saying all of that I forgot this is on a 240, double check with the 240 exerts in the group, my knowledge is 700.
