It is currently Tue Jan 27, 2026 10:15 am
Post a new topicPost a reply Page 1 of 3   [ 35 posts ]
Go to page 1, 2, 3  Next
 Post subject: Stuff in my way
PostPosted: Sun May 23, 2010 11:26 am
One pair of shocks. I was told they're for a 220, and in doing some internet searches it seems that they match up. The part number is 739014, should be a Gabriel Classic Gas, number updates to 82014 which was discontinued in 2004. I guess some early military Jeeps use this shock too... $40
A bunch of these: (2 of Rev. 0, 10 of Rev. 1, 8 of Rev. 2) $5/pair
A pair of these: (Scantech upper mounts for 850 rear shocks) $25
Electronics stuff: (740 head unit installation plate, one pair ground loop isolators, one pair Kicker 100hz crossovers, some random short lengths of RCA wires, 3 each 740 head unit sockets and 740 glove pockets, one each 740/760 stereo, $20 for installation plate, $20 for crossovers, the rest is free.
A Blues BL15-4 subwoofer. Size 10.5 pictured for reference: $40, shoe not included
B234 intake manifold. Absolutely mint and clean: $OLD to Greg
Bi-xenon HID setup for H4 headlights, around 4200k in colour, never used. Comes with easy-to-follow instructions in Engrish. $OLD to Ian
 Post subject: Re: Stuff in my way
PostPosted: Sun May 23, 2010 12:10 pm
Matt, I will take the HID lights ^^^, need to do something on the 740 and these will work great
PostPosted: Sun May 23, 2010 12:12 pm
But wait, there's more!
Pair of Cibie Iode convex-lens headlights for a Renault Dauphine (don't ask). Should you buy these and cut off the tabs, they'd be pretty close to fitting into a quad round 240 headlight setup. $40
Upper/lower rad hoses for a 740 NA, can be cut down for turbo apps. $old to Athal
Gen-u-whine Volvo oil temperature and oil pressure gauges for 740/760/780 instrument cluster. Wiring and senders not included. $75
740/760 arm rest with cupholders. $OLD to Ian
U-joints and center bearing support for 740 turbo M46. $75
Getrag 265 centering ring and pilot bearing. You supply the rest to mount it to a B21/23/230 bellhousing. $30
T5 adapter plate, Rev. 0. Bellhousing mods, pilot bearing, throwout bearing, transmission, etc... all required. $50
850 poly upper mount, used. $20
850 wagon dog gate and bag-o-hardware. $50
740 wagon dog gate and bag-o-hardware. $50
164/264 tails in various condition and completion. $50 for the lot.
140 rockers, buttcheeks, and inner fenders, $75. 240 headlight supports, $20
Volvo caliper brackets for 10" front calipers on a 740/760, NIB. $40
850/S/V/C70 HPT performance kit (NA 850 GLT cams and throttle body). $old to Craig(Don't worry, Craig, your cams are in storage)
Garage TV, includes DVD player. Works just fine. $30
PostPosted: Sun May 23, 2010 1:37 pm
I also take 740/760 armrest w/ cup holder =D>
PostPosted: Sun May 23, 2010 3:00 pm
What's the difference between the b21/23 and b230 waterpumps?
PostPosted: Sun May 23, 2010 4:07 pm
Fewer mounting studs on the B230 pump, and they're in a slightly different pattern I think.
PostPosted: Sun May 23, 2010 11:43 pm
Garage TV? dare I? 8-[
PostPosted: Sun May 23, 2010 11:53 pm
Craig says he will take the other set of cams as well... [-o<
PostPosted: Mon May 24, 2010 12:16 am
Yes please.
PostPosted: Mon May 24, 2010 2:11 am
Somebody should jump on that locker. People sell these on tb for alot more than that.
PostPosted: Mon May 24, 2010 7:40 am
Turbo'd and Intercooled!
What's the mod on the locker? Will it fit '95+ IRS 960?
RT
Volvoless
PostPosted: Mon May 24, 2010 9:35 am
interestin about the water pumps, i would never have thought they were different.
I'll take the coolant hoses.
if the alarm has the capability to control the locks via remote(which i doubt, otherwise i bet you would be using it), i'll take that.
PostPosted: Mon May 24, 2010 10:16 am
The mod is to remove the flyweight that disables the locker above a certain speed. It won't fit in the early IRS because the output stubs are a different diameter/spline than the Dana30/1030/1031/1041. I don't know about the 2nd gen IRS.
The alarm will cook your breakfast, though I don't know if it'll interface with the stock doorlocks in Darth. I'm sure it will just take some fiddling.
PostPosted: Mon May 24, 2010 12:55 pm
Interesting. Looks like I'll be buying a new pump for my donor engine.
PostPosted: Tue May 25, 2010 9:22 pm
The metal for the 140, wasn't it the same for a 240? I didn't think there was a difference between it. IF it would work on my 80 240 I would take it all... Ill try to check part numbers at work tomorrow.
Users browsing this forum: No registered users and 25 guests
