It is currently Thu Feb 26, 2026 11:27 pm
 Post subject: restricted orifice
PostPosted: Sun Aug 08, 2010 3:36 pm
I like cake
Hello everyone,
Just joined the club. I live in Calgary and own an 1996 850R and a 1973 1800ES.
The 1800ES has been converted to SU HIF6 carbs, which makes the car go like gangbusters now. The remaining issue is the high idle (1400-1500 rpm's), which is probably related to the crankcase breather. The person, who rebuilt the SU's says that it needs to have a "restricted orifice" in the intake manifold; a fitting that looks to have a large ID, but has a small ID internally. Who are the best mechanics in the club and reside in Calgary? Who has a longer moment and the gusto to help? Please let me know. Cheers, Ray
 Post subject: Re: restricted orifice
PostPosted: Sun Aug 08, 2010 6:48 pm
Saying "restricted orifice" makes me giggle like a twelve year old...
However, I'd think you have one already (besides the juvenile dirty kind) - most seem to, anyway.
Where abouts do you live? We've got guys all over.
PostPosted: Sun Aug 08, 2010 7:15 pm
Welcome and sorry i cant help with your orifice! Not sure how crankcase and idle arr connected but hopefully one of the even older guys around here can offer some advice. Only carbs i have are on my bike and i havent had to touch them yet!
PostPosted: Sun Aug 08, 2010 7:58 pm
Sounds fun, I got to tune a couple su's at work on some older models. Good luck with getting it running right. Post some pics!
PostPosted: Mon Aug 09, 2010 6:44 am
I'll look at my spec book but you should have a restricted orifice.. in some cases.
Bert & Jacks Auto Service
129 17th ave S.E
228-7078
Paul
PostPosted: Mon Aug 16, 2010 6:13 pm
Your D-jet must have been some messed up that SU's are an improvement....
PostPosted: Mon Aug 16, 2010 10:33 pm
I'd argue that SUs are a slight improvement to the D-jet for power. They don't require extremely frequent attention once rebuilt very carefully on an engine that isn't worn out junk (most OHVs are by now). By this time, they are probably easier to keep on the road, since they are pretty much a known entity with parts available and people available to rebuild them very nicely.
On a fairly "cookie cutter" 2.1 B20 with an R-cam and some fairly minor well done head work, the d-jet will really lean out as the RPMs climb. The SUs with the proper needle to go with that cam and some headwork will keep on pulling and put down decent power.
The d-jet works fairly well and reliably when all is right with it. Good luck finding a completely good wiring harness, injectors or MAP for it though. Fuel pressure regulators also do interesting things if adjusted up much from stock (not saying that is good or bad).
As to the SUs, one ought to be able to find the correct needle to run them with a D-cam B20, if that is what the car has. If the shafts haven't had bushings done and the carbs rebuilt, unless yours are in time capsule condition from 196x-1974, they probably need to be re-bushed before one tunes them or worries about orifices *chortle.*
Worn out carbs or engines won't ever tune correctly. Fresh stock carbs on a stock spec motor are quite painless to set straight and mostly stay that way. SUs are sensitive to elevation changes however, which would definitely describe Calgary-surrounding terrain many times. I used to lean them out a bit (2-3 flats from sea level to sun river (high desert) IIRC).
PostPosted: Mon Aug 16, 2010 10:46 pm
sorry, had a couple of scotches, so can't contribute much. just want to say- james, **** you're smart.
PostPosted: Mon Aug 16, 2010 11:20 pm
On an unrelated related subject. I have a complete D-jet computer/harness from a 71 142E for sale.
