It is currently Fri Mar 20, 2026 12:08 pm
 Post subject: Re: Looking for Snow Tires
PostPosted: Thu Jan 13, 2011 10:01 am
Still looking, still slipping and a sliding.
:wink:
Volvo S40
PostPosted: Sat Jan 15, 2011 9:46 pm
I see a set of 215 55 R16 snow trires on kijiji does anyone know if they will fit the S40, they were on an S80????
thanks
Volvo S40
PostPosted: Sat Jan 15, 2011 11:18 pm
They will be slightly taller than what you have so no speedo issue, but they are wider than what you have now. Personally I would try and stay the same or narrower for winter tires. The rims should be correct offset and for bolt number and diameter, not sure about the hub size though. I think the hub size may be bigger than yours so you could theoretically use these with hub rings and live with the extra width, although my .02 is to keep looking.
Edit: Check out this ad http://alberta.kijiji.ca/c-cars-vehicle ... 251413583#. Appear to be FWD offset in Calgary and $200 for 16" rims and hub caps is reasonable, then you can go and get your own 205/55-16 tires mounted instead of trusting someone else's used crap.
PostPosted: Sun Jan 16, 2011 12:04 pm
Thanks for the link, will check it out. :)
Volvo S40
PostPosted: Mon Jan 17, 2011 8:38 am
http://alberta.kijiji.ca/c-cars-vehicle ... Z254430497
PostPosted: Mon Jan 17, 2011 10:39 am
http://alberta.kijiji.ca/c-cars-vehicles-auto-parts-tires-tires-rims-Five-pin-tires-and-rims-for-Volvo-W0QQAdIdZ254430497
I thought about posting that as well, but if they are from an 02 they should be 4 bolt not "5 pin" whatever that means?? :roll: Might also only be 15" which won't fit an 06 as well.
PostPosted: Mon Jan 17, 2011 10:53 am
Thanks for the help, most of these seem to be older ads, when you call they say the rimsa are sold.. :(
Volvo S40
PostPosted: Mon Jan 17, 2011 1:04 pm
How hard is it to delete your ad when the item sells? It's really inconsiderate of people to waste others time leaving up their dead ads. :evil:
What was your budget again? I was looking at tirerack.com and you could get 16" alloys with 205/55-16 Altimax Arctic's installed and balanced for $680 + shipping.
PostPosted: Mon Jan 17, 2011 5:41 pm
Yes its frustating.
:wink:
Volvo S40
PostPosted: Wed Jan 26, 2011 5:25 pm
http://alberta.kijiji.ca/c-cars-vehicle ... Z256496250
Wheels anyway.... It's a start...
PostPosted: Wed Jan 26, 2011 9:22 pm
Thanks Dale, I don't see a phone or email reply on the ad, is it me??
Volvo S40
PostPosted: Wed Jan 26, 2011 9:25 pm
Cut and pasted id of ad and found the email link :oops:
Volvo S40
PostPosted: Thu Jan 27, 2011 2:06 pm
Got the rims, now awaiting a reply for some tires I found.
Thanks to everyone so far , greatly appreciated.
Bill
:D
Volvo S40
PostPosted: Sat Feb 05, 2011 6:14 pm
Success, have tires and rims, let it snow.
Thanks to all that helped.
:D :D :D
Volvo S40
PostPosted: Sun Feb 06, 2011 3:58 pm
Pics of rims and tires.
Volvo S40
