It is currently Sat May 02, 2026 2:03 pm
Post a new topicPost a reply Page 17 of 22   [ 322 posts ]
Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 22  Next
PostPosted: Sat Jun 11, 2011 11:22 pm
=D> :shock: :P 8) =P~ :D
PostPosted: Sun Jun 12, 2011 6:29 pm
Looks great Matt!
PostPosted: Sun Jun 12, 2011 7:12 pm
Thanks guys.
First drive impressions:
- The car runs silky smooth. Before it used to have a bit of a lope at idle, where the weaker cylinders really showed up. I had leakage through the valves before and of course this is going to be most noticeable when there's a lot of time for each compression stroke to leak out. Now it just idles like glass.
- Broken glass... The added valve clearances are noticeable. I didn't think they would be, due to the very slow open/close ramps. I will tighten them up after I retorque the heads, which I can do now that I've beaten up on it a little.
- At ~2300 the exhaust really begins to bark and resonate. It's sort of a high pitched rattle, rather ricey to my ears. :( Beginning at about 4000 it loses the rattle and starts to sound more like a high performance 6 cylinder, and it sort of holds that to about 5500 or so, where it begins to tone down and sound a bit more strained inside the car. I don't know what it sounds like outside.
- The transmission that used to work very well with the stock B280F doesn't seem as well suited to this engine. It's fine, so long as I shift it manually, but if left in automatic it shifts by itself at about 4500 and doesn't let the engine breathe. Plus, I hate the sound of an obnoxious exhaust and an automatic...
- I was a bit underwhelmed with the power. Even though it runs much better and much stronger at the top end, well, I guess I had it built up in my head that I would change the spinning axis of the earth every time I stepped on the gas. I sure didn't MEAN to build up that expectation, which is completely unreasonable since AT BEST I was going to see 180 hp. I figure I'm probably pretty close to that, but it would really wake up with some B280E cams and an M46. Part of the underwhelming-ness probably came from the fact that I never really revved the old engine, because it didn't do any good. This one pulled strongly to 5500 and beyond on my first drives, but I didn't have much to compare it to.
- The engine ran quite lean on my first drive, around 13.7-13.2 to 1 at WOT, once it got off the oxygen sensor. Not horrible, but still probably giving up some power. Around town and on the highway it runs fine and stays on the oxygen sensor, so runs in the 14.5-15.0 to 1 range. Stomping on it at 100 kph drops it out of OD and into 3rd, where it pulls pretty well to 4500 and then back into OD at about 130. When it's in 3rd it is in the high 13:1 range, and then when it goes into OD it seems to mostly be back on the oxygen sensor. Good for economy, not great for power.
- Near the end of my run, after getting the tank to just over half on the gauge, I started to get some pretty good lean stumbles when I nailed the gas. Finding the pattern, it happened after a hard pull on the brakes and then getting back on the gas aggressively. It only happened once or twice, usually when I was pulling in 1st gear, and then it pulled as hard as normal from the next gear on.
Getting home, I pulled the in tank fuel pump and discovered that it was not working. It was giving me some troubles the last few times I drove it: when the weather was extremely hot, occasionally the car would die. It would crank, and once I pulled the return hose off the FPR and nothing came out, so it was fuel. I kind of thought the radio suppression relay was giving me grief, but that only triggers the injectors, not powers the fuel pump. Maybe the fuel pump relay was bad, and shutting off in the heat. I swapped them both last summer. I also had some issues similar to what I discovered at the end of my drive, where the car would stumble and stall sometimes on hard acceleration after braking, but I never had a wideband on it before now to see what was going on.
Anyway, after changing the pump I went for a quick drive and the AFRs were now in the low 13s to mid 12:1 range at WOT/redline, and it seemed to pull harder in the top end than before. It also failed to give me that stumble after hard braking, so I think the problem is fixed. Hopefully too, the fuel pump relay will stay cooler and will not fail me in hotter weather. I only did a short drive so I don't know if I nailed the problem or not, or if it has a bunch more power than before.
So am I happy? Of course not. I'd like to deal with the rice factor and I want more power, but I'll live with both for now. I think it now needs a manual transmission more than before, and that will work well with the locker, especially if I put a lighter flywheel in there. Next winter jobs... There are a couple other things to deal with after I get driving it, rattling door panels and getting the air/cruise functioning, but those are for later.
Next step, trunk and roof paint.
PostPosted: Sun Jun 12, 2011 9:11 pm
Very nice work Matt. =D>
PostPosted: Sun Jun 12, 2011 10:14 pm
Hi. That was tons of work, and I enjoyed reading about it.
More-or-less on schedule too!?
PostPosted: Sun Jun 12, 2011 11:09 pm
Hey, you built your v8 (about six times, if i recall) so you really shouldn't be expecting that kind of power/torque, right? It's a (very olde?) school V6, so 60hp/L is a reasonable expectation/goal. I don't think you planned to build a rocket (at least until the turbos go on).
It would be really nice if the fuel economy is better too.
Why does this sound familiar? Oh yeah, because I'm kind of half disappointed with all the work (about 10% of what you did) on my motor too...
PostPosted: Mon Jun 13, 2011 11:32 am
@Jim - no, nowhere near schedule. I'd hoped to have the paint repairs done (which I hope to have done by the end of June) a couple weeks before IPD back in May. I sort of lost motivation a few times, though...
@Athal - I think it's all first impression blues, maybe for both of us. I have the trunklid off the car for sanding right now so I won't be driving it for a while, so hopefully now that my dreams have been knocked down a peg or two I'll be more satisfied with it when I drive it again. I'm still thinking a cat or a different rear muffler will be in order, though.
PostPosted: Mon Jun 13, 2011 6:48 pm
Matt, very interesting build you have there,quite the eye for detail =D>, I wouldnt know where to start. I see you're using a Magnaflow...it is very similiar to the one I use,and I kinda have the same complaints,too raspy,and not deep enough in the mid rpm's.I have been tossing around changing it out for another, any ideas?
Alex.
PostPosted: Mon Jun 13, 2011 9:15 pm
It's raspy in your V8 car, Alex? Wow.
I've had no rasp from the other Magnaflows I've run, but none before now have had the integrated fart can. The Magnaflow and Dynomax are the same design, so I'll probably buy either one in an oval housing and do an "S" tip like I did in my 745. Classic Volvo style and it really tones down the flutter & rasp.
I'll make sure it's level this time, tho...
Edit - in fact, I might just cut off the fart can and add the tip to the existing muffler.
PostPosted: Mon Jun 13, 2011 9:40 pm
The Magnaflo on my 122 was just a touch raspy iirc... :lol:
PostPosted: Mon Jun 13, 2011 9:44 pm
Ehh? I didn't think it was a Magnaflow. I thought it was just a chambered baffled muffler. It's been a while tho so I'll admit I've forgotten.
Edit - Different style, totally, but it was a Magnaflow. XL series, baffled and chambered versus straight through glass packed. I forgot they made them as well as the glass packed ones like mine. Yours was definitely raspy, tho!
http://www.calgaryvolvoclub.com/gallery ... 5.jpg.html
PostPosted: Mon Jun 13, 2011 10:34 pm
That's LH 2.2 right? I wonder how much you've changed the timing requirements with all the motor work. Might be a bit of power on the table there, if you can do more than just alter the base timing. Worth playing with a bit I guess- does it require premium?
PostPosted: Tue Jun 14, 2011 3:14 am
I musta watched this video a dozen times so far, and I still laugh like an idiot every time!
Just watched it at work...I lol'd
very cool thread Matt, (cue Waylon)....the good ole boys of this group do some amazing work, I am impressed anytime I read through a project build thread
PostPosted: Tue Jun 14, 2011 4:42 am
@Athal: Fuel is 2.2, but spark is EZ115K similar to 2.4, therefore not adjustable. I haven't tried premium in there, I always burn regular.
@ Vik: Thanks bud!
PostPosted: Tue Jun 14, 2011 9:52 am
Good you can use regular. If it's not pinging you're obviously not losing anything there. So it has a crank sensor? Interesting. Guess all you can do is some of the ICU pin tricks to adjust the overall curves a bit.
Not exactly a fast burn chamber from what I can see, so maybe more timing would help...
