It is currently Tue Mar 17, 2026 5:47 am
 Post subject: How did everyone else deal with this? (+T question)
PostPosted: Thu Dec 15, 2011 12:29 pm
Vmax 200mph w00t!
Hey all,
I just finished a +T job on a 745 with a B230F and Garrett T3.
Runs and drives great...but i noticed it started leaking oil like a mofo.
I had put in a 9/16NPT(iirc) T fitting in place of the stock oil pressure switch to feed the turbo and an oil pressure sender... taking it apart i found this...
Whoopsies. :?
How did others deal with this? Can i get some sort of M14 to 9/16NPT fitting?
Should i go with pipe threads or keep it straight threaded with an oring?
I'm half tempted to just hack off the switch and weld it to the T fitting...
94' 944t "The Good One"
87' 780 5.0L V8
 Post subject: Re: How did everyone else deal with this? (+T question)
PostPosted: Thu Dec 15, 2011 12:47 pm
Vmax 200mph w00t!
wait...by 9/16NPT i meant 3/4NPT
87' 780 5.0L V8
PostPosted: Thu Dec 15, 2011 12:48 pm
I THINK you meant 3/8" NPT. 3/4" NPT is just over 1" in diameter.
At the very front of the block is a 1/8" NPT galley plug. I've used this in the past.
Edit - the B230 (metric machine thread) fitting is sealed by a copper washer, not by the threads, IIRC. NPT piping is sealed by the threads. You might be able to find an adapter but you'd be just as well off using the galley plug at the front of the block and bending up some 1/4" tube to get it to the turbo. You'll want a swagelok or some other kind of ferrule unioned fitting, I'm sure. Or a hose with unioned ends, but you'll have to make sure you support it well enough.
PostPosted: Thu Dec 15, 2011 8:53 pm
Turbo'd and Intercooled!
For what it's worth, you may want to avoid brass fittings on an oil feed line as those are more prone to breakage than steel or stainless fittings.
RT
Volvoless
PostPosted: Fri Dec 16, 2011 8:50 am
Vmax 200mph w00t!
Thanks for the feedback guys! I'm still doing some homework over here to find the best solution.
@Gasbrick: What type of 'breakage' are you referring to?
87' 780 5.0L V8
PostPosted: Fri Dec 16, 2011 9:18 am
They can break from vibration, especially if you have hard piping or a heavy sensor, shut-off valve, etc screwed into the fitting. They will normally fail at a thread root. A few +T-ers on T-bricks have documented these failures. I have seen it on generators and diesel engines (lukily with oil pressure engine shut-off switches). Steel fittings are more forgiving of abuse and much more resistant to fatigue failure.
RT
Volvoless
PostPosted: Fri Dec 16, 2011 11:50 am
I've made this mistake on my own, with an early attempt at adding an oil temp sensor to the oil pressure tap. Fortunately it only cracked and leaked everywhere, rather than dumping all of the oil pressure. If it happens on a turbo feed you'll lunch the thing pretty quickly.
PostPosted: Fri Dec 16, 2011 1:56 pm
Vmax 200mph w00t!
well, i suppose i'll be learning things the hard way as well...just grabbed $3 worth of fitting adapters to make it work, lol
However, I'm replacing the electrical oil pressure gauge with a mechanical, so there will be less mass supported by the assembly...we'll see how it goes i suppose.
Everything i do seems to be an iterative process of making mistakes and doing it properly later...this car is no exception, lol
87' 780 5.0L V8
PostPosted: Sun Jan 08, 2012 7:27 pm
You know that there is a factory electric oil pressure gauge and sender found on all 240 turbos. Mechanical oil pressure gauges are just a leak waiting to happen for the same reason your brass T fitting will leak/break.
Also use the galley plug at the front of your block for your turbo oil feed, use a proper -An line or have a steel hardline made. If you dont do it right it may cost you your turbo or engine.
PostPosted: Fri Jan 13, 2012 7:26 am
I can't comment on your pressure switch selection, but regarding the adapter there's a great place in town that sells all types of adapters and fittings...
Green Line Hose & Fittings they have two different locations in Calgary
http://www.greenlinehose.com/locations.htm
You can navigate their website to find their adapters section or...
http://www.greenlinehose.com/_pdf/pulsar/Adapters.pdf
Follow the link and go to page 93 or 94 of the actual document by referring to the page number on the bottom left and/ or right of each page. You are looking for BSP to pipe (NPT) adapter 93 is male NPT and 94 is female.
You may notice the sealing washer in some of the pics. It is included with every adapter for the BSP side of the adapter...
Good Luck
Ahmad
PostPosted: Mon Jan 23, 2012 4:57 pm
Vmax 200mph w00t!
Thanks for the link, i definitely went to Greenline for assistance with this and they gave me the aforementioned $3 worth of fittings, but i haven't actually seen their catalog. The M14x1.5 thread adapter they gave me had an oring and such with it, made for a good fit.
The reason i chose mechanical fittings is due to a set of mechanical autometer gauges i "Liberated" from a buddy's Nissan s13.
87' 780 5.0L V8
PostPosted: Tue Jan 24, 2012 8:13 am
Vmax 200mph w00t!
By the way, how much clearance do you get at the front galley plug? does anyone have a picture of their setup?
87' 780 5.0L V8
