It is currently Sun May 03, 2026 11:08 am
Post a new topicPost a reply Page 1 of 3   [ 44 posts ]
Go to page 1, 2, 3  Next
 Post subject: 92 940 turbo Part out
PostPosted: Fri Mar 02, 2012 10:40 am
Vmax 200mph w00t!
Hey team,
I have a 92 944t parts car, located in Saskatoon.
Sway bars, and front end is called for. But everything else is up for grabs that i can pull & ship.
Make me an offer, i'm pretty lax on price, (this car owes me nothing)
I can throw up pictures of anything you need.
If you need something larger, like the engine/tranny/wheels, we may be able to work something out.
notable bits are:
-b230ft squirter block (240k-ought Kms on it) - $150
-13c turbo - $50
-15" BBS (legit) rimps - $200
If someone wants to do an LH2.4 conversion, I can pull everything you need.
cheers!
-Sol
94' 944t "The Good One"
87' 780 5.0L V8
 Post subject: Re: 92 940 turbo Part out
PostPosted: Fri Mar 02, 2012 12:30 pm
Hmmm any way to check compression on the motor? Just a crazy thought but if I swap in a decent bottom end earth might be close to perfect though maybe more work than worth while if I'm going to sell...
PostPosted: Fri Mar 02, 2012 12:31 pm
i will buy the motor pretty please
PostPosted: Fri Mar 02, 2012 1:04 pm
Vmax 200mph w00t!
Sure i can grab compression numbers tonight/this weekend and throw them up.
I will warn you tho, at this point...the only form of shipping i'm willing to do is if someone brings a flat surface on wheels that i can drop it on to.
87' 780 5.0L V8
PostPosted: Fri Mar 02, 2012 4:57 pm
Well I have the time right now so if I can get a truck it might be a good idea.
Porvolvo what do you need the motor for?
PostPosted: Sun Mar 04, 2012 1:05 pm
Any luck on the engine test?
My wifes uncle runs trucks through there all the time, I'll see if one of his guys can pick it up and at least get it to Edmonton.
Is that a tan interior?
PostPosted: Sun Mar 04, 2012 1:30 pm
Vmax 200mph w00t!
Hey there, I should have numbers for you tonight...but to be honest I probably won't get to pull the engine for a week or two, my other car needs a driveshaft before I can get it off the stands.
Yes, tan interior but it's kinda poopy. I'll throw up pics tonight
87' 780 5.0L V8
PostPosted: Sun Mar 04, 2012 3:44 pm
Does that have the centre in-out IC with the bigger radiator too? If so, and the rad isn't leaking, I'll take it.
No rush on the engine for me, at least for now!
PostPosted: Sun Mar 04, 2012 8:56 pm
Vmax 200mph w00t!
Did a compression test, results aren't great:
120, 115, 120, 135
I don't feel like it's worth my time to pull, but I'll leave it upto you guys if you still want it.
Here are some more pics:
^ poopy looking bay, haha
Interior shots. Seats are leather but they're kinda weathered... Am i the only one who doesn't think leather = better?
Yep! as far as i can tell both are in good condition. Did you need the associated rad + IC Piping as well?
87' 780 5.0L V8
PostPosted: Sun Mar 04, 2012 9:56 pm
Nope, I've got everything, just have a leaking rad (2years old, grrr) and rather not order a new one if I don't have to.
The interior I might get the door cards if they were clean. Later 940s used a material that quickly got all wrinkled. Only if I was picking up the motor or something, not worth shipping.
You checked the motor warm, all plugs out, throttle open? Those numbers all seem low- mine is 130, 145, 155, 155 (or something like that).
The rad and piping you could probably sell on turbo bricks, it's generally considered an upgrade over the standard 740/240 intercooler.
PostPosted: Mon Mar 05, 2012 8:17 am
Vmax 200mph w00t!
Hmm, well i did it with the engine cold actually...i suppose i could do it again to see if the numbers improve.
87' 780 5.0L V8
PostPosted: Mon Mar 05, 2012 9:13 am
Makes a huge difference once those pistons and rings are warmed up in the bores!
PostPosted: Mon Mar 05, 2012 9:46 am
Vmax 200mph w00t!
yea? maybe i should redo the compression test on my 'good' 940...it had stellar numbers, and i used the same cold testing method :lol:
87' 780 5.0L V8
PostPosted: Mon Mar 05, 2012 10:10 am
Doesn't hurt for interests sake- I think my cars numbers cold were somewhat similar to yours. Makes sense as I pull about 10in vacuum when the car first starts, then down to ~15in when it's warmed up.
PostPosted: Mon Mar 05, 2012 10:50 am
Hey swedishmeatball i plan on doing a complete motor rebuild on it with rsi pistons and rods with a well worked over head,megasquirt and a big turbo
