It is currently Mon Mar 30, 2026 10:00 am
 Post subject: Alternator/Regulator matchup
PostPosted: Fri Oct 26, 2012 1:57 pm
Does anyone know how to check the alternator/regulator compatability? The bearings on my 35 amp alternator are too worn to fix but I have a spare 55A.
13038 12V 55A. I don't know what it came off of, it came with the car. The alternator bodies are identical.
67 122s b20
 Post subject: Re: Alternator/Regulator matchup
PostPosted: Fri Oct 26, 2012 9:07 pm
Hi Ian,
That alternator came from either a late 140 series of a 1975 240. Essentially, all FI cars got the 55 A alternator. They need an external regulator and they are all the same as far as I know.
Check it out from the usual suppliers - though I was able to source one through World Pac from Calgary...in other words, go to Auto Value or Napa and they can get you one in a couple of days and save the shipping.
PostPosted: Fri Oct 26, 2012 10:58 pm
Thanks Craig. After I posted I went down to Hagen and they said both alts used the same reg. My plan now is to put in the 55A and upgrade the wire. Sound ok or am I missing something?
PostPosted: Sat Oct 27, 2012 6:03 pm
Other than cleaning all your grounds and fixing up that fuse box - you've got it aced.
PostPosted: Sat Oct 27, 2012 8:57 pm
Done. I think the problem on the cruise was just the regulator connection. Dirt and rust. Cleaned the grounds anyway and changed a few terminals. Getting 14 now. Who's up for a drive? :oops:
PostPosted: Sun Oct 28, 2012 9:42 am
Now you're cooking. That looks like it should do the trick. Stainless screws, I hope?
