It is currently Wed Mar 11, 2026 5:24 am
Post a new topicPost a reply Page 9 of 9   [ 133 posts ]
Go to page Previous  1 ... 5, 6, 7, 8, 9
PostPosted: Wed Oct 30, 2013 8:00 pm
Well...after humming and hawing I ended up just buying a Lincoln 120v welder to get the exhaust done. It fit perfectly under my Napa tool cart and I've now converted it to be my welding cart with a bracket to hold the bottle (not pictured). My original plan of cutting and using masking tape to hold sections together and driving an hour to my dad's shop an hour away to use my 220v welder was quite inefficient haha. I went 2.5" and started cutting up some tubing and eye balled most of it. It's really really tight for space in there and couldn't fit my measuring tape up there. I had to cut off the header flange and rotate it so the stud wouldn't hit the frame. I added an H pipe under the tail of the transmission (not pictured yet). It then goes into a Dynomax Race Bullet on either side. I built the H pipe and "mufflers" as one so if I don't like the sound its easy to undo 6 flange bolts and it'll come right out. I ground down the welds and coated them in vht header paint. I was told the dynomax bullets sound amazing but are unfortunately the loudest on the market. I'm quite limited for space however so these seemed like the best option. The exhaust coming from the mufflers will be turned down and out to the side before the rear tires because I won't have enough clearance between the floor and rear diff when the suspension is slammed.
Ill get some more pictures this week hopefully.
What I did was buy a 2 U shaped mandrel bent tubing from our local hot rod shop and started cutting. Started with this and just added more on as I went.
I ground the welds down (some of the first ones weren't very pretty but by the end I was getting the hang of it and had the settings dialed in)
(Below is pre welder purchase lol)
I then coated them in VHT black header paint.
I'm starting to see why I was quoted $1500 for a custom exhaust...it took some time to get it all to fit. So far I think I've spent $900 with the welder and bottle of gas included. But now I have a welder at my disposal if I want to change it up.
This is what the race bullets should sound like:
[youtube]http://www.youtube.com/watch?v=nBOOVIuig0w[/youtube]
PostPosted: Tue Nov 12, 2013 11:01 am
Took her out for a drive today. Hopefully the weather stays nice and I can get some shots with my dslr. Also did a bumper tuck and tossed a lip on.
PostPosted: Tue Nov 12, 2013 1:40 pm
Very nice, you have done a fantastic job on that car. =D> I'm really impressed how well that old paint buffed out, loving the retro wheels, trim rings and caps. We need to do a cruise next spring just so we can all have a look in person and listen to that exhaust.
PostPosted: Mon Aug 29, 2016 2:34 pm
Massive bump!
This thread escalated rather quickly and I love every minute of it. Is it still in Calgary?! I never see it in car shows or anything.
I miss air bags. I had it on my Golf R and looking to do the same for my wagon. [-o<
Don
PostPosted: Tue Aug 30, 2016 9:12 am
It's in the chuck now I believe, and been for sale for some time. You should buy it!!
PostPosted: Tue Aug 30, 2016 11:23 am
Oh man... So tempting.
Don
PostPosted: Mon Oct 17, 2016 6:42 pm
Ouch!!!
http://www.kijiji.ca/v-cars-trucks/calg ... nFlag=true
PostPosted: Mon Oct 17, 2016 11:14 pm
:shock:
PostPosted: Tue Oct 18, 2016 3:57 pm
That's a big wtf right there
PostPosted: Sun Oct 23, 2016 10:05 am
That's coconut Colin selling it. He was so excited when he bought it. He had a post on tbricks about it. Didn't turn out very well.
PostPosted: Sun Oct 23, 2016 10:27 am
Coconut Colin lives in Alberta??
PostPosted: Sun Oct 23, 2016 2:07 pm
Sure does! He is in Calgary!
PostPosted: Sun Oct 23, 2016 6:26 pm
Yikes. Anyone heard from Carter? Seemed like he did top notch work...
