It is currently Sun Mar 22, 2026 2:56 am
Post a new topicPost a reply Page 2 of 2   [ 20 posts ]
PostPosted: Sun Apr 30, 2006 11:40 am
The one that's in my white car has three cracks. No daylight = no leak.
PostPosted: Sun Apr 30, 2006 11:44 am
my 90+ has one crack...but again no light came through when i inspected it
over torque your manifold studs until they break, then back off a bit that's how i knew when mine were tight :roll:
use new gaskets?
PostPosted: Mon May 01, 2006 6:52 pm
New question for you guys. Its running well....except it is too rich. Could this be because of the cold start injector being stuck open? also if my timing was a tooth off would that affect comsumption as well? thanks!
PostPosted: Tue May 02, 2006 12:08 am
are you reading richness off plugs or an A/F meter?
PostPosted: Fri May 05, 2006 2:34 pm
I'm reading richness off the fact that i can smell gas in the exhaust as well as using a tank in 200km...
