It is currently Fri Mar 20, 2026 11:45 pm
 Post subject: Performace clutch/pp combo for B230/M46?
PostPosted: Thu Mar 26, 2015 9:14 am
Vmax 200mph w00t!
Hi all,
What's the best/cheapest way I can get a moderate performance clutch and pressure plate for a flat flywheel b230 with M46? From within Canada preferably.
I'm temporarily throwing in the towel on my world class T5 swap into the 940 and I will return to the project when my frustration levels have subsided.
Thanks,
-Sol
94' 944t "The Good One"
87' 780 5.0L V8
 Post subject: Re: Performace clutch/pp combo for B230/M46?
PostPosted: Thu Mar 26, 2015 11:57 am
solyeahman wrote:
Hi all,
-Sol
Buy my 740... :lol:
PostPosted: Thu Mar 26, 2015 12:14 pm
How much power do you plan on making?
Maybe I've been lucky but when I did the clutch on my 244 in 2001 it survived all this time and broke one M46 (12psi, third gear pulling a fair sized trailer).
It was just a sachs replacement clutch and PP on a flat flywheel.
Its life in the last 5 years has been easy but the first 5 years would of been torture.
PostPosted: Thu Mar 26, 2015 4:17 pm
Vmax 200mph w00t!
Well, the car is making enough power that the brand new sachs clutch and pressure plate that I had with the dog-dish flywheel was slipping every time I put the pedal to the floor...
So somewhere above the 220ft-lb mark?
87' 780 5.0L V8
PostPosted: Thu Mar 26, 2015 4:19 pm
Vmax 200mph w00t!
solyeahman wrote:
Hi all,
-Sol
Buy my 740... :lol:
Don't tempt me...i'm trying to thin the herd over here. :lol:
Also. i think your 740 is worth more than my whole project...
87' 780 5.0L V8
PostPosted: Fri Mar 27, 2015 7:13 pm
I'm almost sure you have a problem somewhere else.
Is it cable or hydraulic operated clutch?
I personally had a problem on a 240 where the fork attached inside the bellhousing (it was loose about to fall apart).
Ive also heard of bent forks.. not sure if I believe it though.
Was your flywheel resurfaced? You received the right part numbers?
I once installed the throwout bearing backwards.. I remember having to pull the trans right after getting it together.
I wouldnt be ordering a new clutch at only 220 ft lbs.. I think I dyno'd that in Calagry in 2006 and still have the same clutch with more boost.
Just dont want to see you spending unnecessary money on m46 stuff. I may be wrong but countless tire shredding clutch drops in my younger days makes me have faith in factory replacement clutches. The rear had been welded for the last 5 years (not driven much though) but it's not like I'm only spinning one small tire, always 2 225/45s.
