It is currently Wed Mar 25, 2026 2:24 am
Post a new topicPost a reply Page 5 of 6   [ 80 posts ]
 Post subject: Re: HUB's 1968 122s Wagon Project
PostPosted: Sat Apr 04, 2015 9:21 pm
Good luck! Are you going to test fit in the slanted position?
PostPosted: Sun Apr 05, 2015 6:01 am
Not starting that project yet. That will be a few years. I had a lot of IPD gift cards sitting around. So I ordered a new carb, header, and a few other little things. Want to be able to drive this everyday with no worries.
HUBBARD
68 122s Wagon
B230FT Swap in 122 Discussion
PostPosted: Sun Apr 05, 2015 9:22 am
Did you buy the Weber carb set up and IPD's header? Is that what you're saying? How's your compression? How's the cam (measure the lift) - most of these engines have rounded cam lobes that make them run like dogs. Cam swaps are done with the engine in the car. The Weber carb is not recognized for it's performance ability - the SU's are. The latest incarnation of the IPD header is not optimal and the stock set up (dual down pipe) is fine for up to 160 hp.
PostPosted: Sun Apr 05, 2015 9:42 am
Yes I did. Wasn't really going for performance. Just needed something more reliable. The SU's need rebuilt and the cost is almost as much as the weber. Since I had GC sitting around, just used them and didn't pay anything out of pocket.
The pvc valve was plugged and got a new one and had that bottom collector cleaned on the driver side of the engine.
We did a compression check when I first got the car. I forget the numbers, but nothing warranted us to take apart the motor.
Didn't/ haven't checked the cam.
Order a spare distributor and will clean it. Will see how the car responds to this one (since the car keeps going full advance). Cleaned the current one and put new springs in. Will see how the car response to this one too.
Thanks,
HUBBARD
68 122s Wagon
PostPosted: Sun Apr 05, 2015 2:09 pm
The SU's are very reliable when in good shape, I don't have Craig's experience so I go with what he's saying which corresponds with what I have read on Brickboard et al. My SU's are out for rebuilding right now and the cost is $C 425 so about $US 340, I'd save the GC's for suspension goodies, brakes etc.
PostPosted: Sun Apr 05, 2015 2:16 pm
Mine aren't reliable due to them needing work. I was unable to get them rebuilt for that price so went with something else.
Suspension and brakes will be next.
Thanks,
HUBBARD
68 122s Wagon
PostPosted: Tue Apr 07, 2015 3:05 pm
A few of the parts came in today...
HUBBARD
68 122s Wagon
PostPosted: Wed Apr 15, 2015 1:50 pm
Well I started the process of getting everything bolted with the help of my step father. The process was a lot of fun.
Well we had two helpers that joined us, but they didn't offer a lot of help. Haha.
Replaced the motor mounts and switched over to a electric fan...
Bolted up the header and the tried to put on the manifold for the new carb. Ran into a little problem. Manifold wouldn't bolt up due to flanges on the bottom hitting the flanges on the header. I wasn't happy considering this should "bolt right up." O well... Nothing the grinder couldn't fix...
After that, it was pretty straigh forward with getting eberything bolted up. Ran temporary lines just to see if it would start and would clean it up later... At least, that is what we thought the plan would be...
Car started and was trying to do the timing and get everything dialed in, but the car wasn't running right. It felt like a cylinder wasn't firing.
I wasn't able to do a compression test, so we pulled all the plugs and did it by "feel." We could feel anything from cylinder 4. So we knew the head had to come off.
HUBBARD
68 122s Wagon
PostPosted: Wed Apr 15, 2015 1:53 pm
Took the head off today. Looks like cylinder 4 was defiantly my problem child.
HUBBARD
68 122s Wagon
PostPosted: Wed Apr 15, 2015 7:13 pm
Looks like some serious valve recession. Better get some seats in that thing.
PostPosted: Wed Apr 15, 2015 7:17 pm
Yes sir. Will be redoing the entire head. Spoke with the previous owner and it's all original. It's time.
HUBBARD
68 122s Wagon
PostPosted: Thu Apr 16, 2015 8:18 am
The head has been dropped off to the machine shop. Will find out if the head is a candidate for new valve train.
HUBBARD
68 122s Wagon
PostPosted: Sat Apr 25, 2015 8:04 pm
Update: The head was cleared as good for no cracks. So I guess that is good. However, the entire valve train is shit. So will start ordering parts next week.
I felt frisky today, so I got a cigar, made some coffee, and went to town.
Also stumbled across a new heater valve. So i picked that up and will rip the entire heater box out... Still trying to figure how this bloody thing comes apart... May need some Scotch :wink:
HUBBARD
68 122s Wagon
PostPosted: Sun Apr 26, 2015 6:00 pm
More taken apart today.
HUBBARD
68 122s Wagon
PostPosted: Sun May 03, 2015 5:10 pm
Heater box removed and did some wiring.
HUBBARD
68 122s Wagon
