It is currently Wed Jul 02, 2025 1:42 pm
 Post subject: 1988 244 M47
PostPosted: Fri Mar 13, 2015 7:51 pm
Well...the time has come to clear out the excess baggage. The 22,000km 744 arrives tomorrow and I just bought another E55T last night.
As the title says, it's an '88 244 with an M47. It's been my winter beater for the last 3 winters. I have put the following on in the last 10,000km....
Bilstein HD rear shocks
Ball joints
Tie Rod ends
Back half of the exhaust
Front and rear rotors
Battery
The odometer reads 200k and change but that's not accurate. The speedo/odometer was not working when I got the car so I swapped in a PnP piece. The old one was in miles and I believe it said 140k. The car came with some odd-sized 14" winter tires and I'm currently running some 195/65/15 Hankook winters. I'd rather not sell the car with those and I do have a couple of options available.
The car needs a couple of things to help it run better. That's not to say it doesn't run good; it could run better. I get about 400k to a tank. It needs a downpipe-manifold to cat. I've got a brand new one but haven't had a chance to put it in. I suspect it might need an O2 sensor and I've got one...I was going to put it in when I put the downpipe on.
The car has never left me stranded and I've never plugged it in. I honestly couldn't tell you if it has a block heater. I suspect it doesn't as it was sold new in West Virginia.
It's not perfect...not even pretty, but is a good solid base for someone who wants to play a bit. It doesn't burn a drop of oil. It could use a different cam as the M cam runs out of breath about 4000 rpm, but that's how it came from the factory. It's got loads of bottom-end grunt.
Asking $1200. It's not in Kijiji yet as I don't have any pictures of it yet. However, I did shoot this short video last weekend and the car shows up at the end...
https://www.youtube.com/watch?v=6c3bIO_FgQU
 Post subject: Re: 1988 244 M47
PostPosted: Mon Mar 16, 2015 4:04 pm
How bad is the rust? If I remember correctly the '88 is the first year for galvanizing.
All I can really get from your video is that the hood has a rusty leading edge, which is not really a surprise to me, and not a problem either.
PostPosted: Mon Mar 16, 2015 5:49 pm
That's about it for rust. There is some showing in the drain holes on the front door, but nothing serious.
PostPosted: Thu Mar 19, 2015 6:35 pm
Just wondering if you have any photos yet. I might have a line on someone buying my 760 and if so I'm interested in your 244. Just want to be sure before I sell
90 740tic
PostPosted: Thu Mar 19, 2015 8:17 pm
I've been pretty busy getting ready for a road trip so no photos yet. I'll try to get some tomorrow...
PostPosted: Fri May 15, 2015 10:13 pm
Finally got it listed on Kijiji...
http://www.kijiji.ca/v-view-details.htm ... 1072576254
PostPosted: Fri May 22, 2015 2:10 pm
And sold. Up next, the road warrior... Suburban 6.5L Turbodiesel.
PostPosted: Fri May 22, 2015 2:35 pm
One down...3 - 4 to go?
PostPosted: Fri May 22, 2015 2:41 pm
No, now you have a free slot for another.
PostPosted: Fri May 22, 2015 2:45 pm
Suburban, Versa and 744 to go. Cleaning up the Suburban today...
PostPosted: Fri May 22, 2015 2:47 pm
Nope...making space for the other one that is already here...
