It is currently Thu Apr 02, 2026 3:38 pm
 Post subject: intercooler
PostPosted: Mon Jun 29, 2015 5:51 pm
Have a 1990 Toyota Celica ST185 GTfour with an I/C turbo 2.0L engine that someone replaced the intercooler with a tube, probably blew the I/C. It's a top mounted cross-flow unit. Does anyone have something that would work in this case. Cheapest online starts at close to $400 so a good used adaptable unit would be nice. Plse fellas, any ideas?
 Post subject: Re: intercooler
PostPosted: Tue Jun 30, 2015 9:14 pm
Be helpful if you had an idea of the rough size you need.
PostPosted: Sat Jul 11, 2015 10:57 am
Picture of the layout it needs to fit would be good as well, as I assume there is some under hood venting to cool it. If you don't have it vented properly the tube is better otherwise it'll be an inter-heater - much worse than just a pipe.
