It is currently Fri Mar 27, 2026 10:19 am
 Post subject: Anybody have a spare Mitsubishi turbo?
PostPosted: Sat Feb 27, 2016 11:59 pm
Turbo'd and Intercooled!
Hey crew. Looks like I blew a seal on the turbo tonight. Anybody have a spare Mitsubishi turbo I could buy, or even borrow while I track down a replacement?
Thanks!
Trevor
 Post subject: Re: Anybody have a spare Mitsubishi turbo?
PostPosted: Sun Feb 28, 2016 9:04 am
I know a guy at work with a brand new WRX-spec TD04, if nothing shows up here.
PostPosted: Sun Feb 28, 2016 10:28 am
Make sure you're PVC system is working properly...if the engine gets pressurized, it will blow oil out the turbo seals.
PostPosted: Sun Feb 28, 2016 12:31 pm
If you can't find one, pick n pull might be a good place to check. I've got a buddy who's pulled a few DSM turbos from there.
PostPosted: Wed Mar 02, 2016 10:47 pm
All is well again. I found a 16t at the junkyard. Came from a crashed s70 T5 with 220k, feels pretty tight.
Turns out the issue with the old one....the nut at the front of the compressor came off, which allowed the turbine to push back, allowing high pressured oil into the exhaust + a ton of smoke.
Car is up and running happily again :)
Thanks for the replies crew!
