It is currently Sun May 03, 2026 9:28 am
 Post subject: Overly sensitive knock sensors on B280F
PostPosted: Fri Jun 30, 2017 1:07 pm
I cleaned the throttle body and reattached everything (so I thought)
yesterday.
Today, I took it for a drive and when the car idled, the rpms started
jumping up and down.
I checked around and found a loose rubber grommet which secures
the plastic intake between the MAS and the throttle body. Pushed that
in back - which I think stopped it rattling against the engine.
Idle went back to steady smooth.
Is this a common problem? Some small vibration tricks the knock sensors.
I read about this on another forum. The guy replaced the knocks sensors
with less "sensitive" ones.
