It is currently Tue May 05, 2026 9:38 am
Post a new topicPost a reply Page 2 of 2   [ 28 posts ]
PostPosted: Sat Sep 30, 2006 9:58 pm
J-Hop wrote:
ive decided to cut my loses and go pull another intake and make sure its not cracked
I'm likely heading to pyp tomrrow...I'll grab you one if you want. They're pretty plentiful and most already have the rail, injectors and fpr removed...
PostPosted: Sun Oct 01, 2006 1:26 am
thanks for the offer dale, but ill probably be heading up early morning tommorrow, Im hoping to get the car back on the road tommorrow, maybe i'll see ya there!
oh and andy, i might still stop by depending on if i get the car back together or not, ill give you a shout and see what your up to.
PostPosted: Sun Oct 01, 2006 9:13 pm
lets hear an update as to how this went?
PostPosted: Sun Oct 01, 2006 11:46 pm
hmm, well it didnt seem to have any effect on my boost problem, although i feel alot better with a proper intake manifold in there, i think im going to hook up the MBC tommorrow and see if i can up the boost a little, i wonder if the spring is worn in the wastegate actuator? we'll see if she will boost better tommorrow
PostPosted: Mon Oct 02, 2006 8:52 am
disconnect the wastegate vacuum line from the turbo, see if it'll boost past 3 or not.
PostPosted: Mon Oct 02, 2006 10:56 am
yea thats what ill probably end up doing first today, BTW raz could you delete or reset my photo album on the gallery, ive forgotton my password :(
PostPosted: Mon Oct 02, 2006 12:36 pm
yea i did that and the car boosted great, it started boosting a bit after 2000rpm and as the rpms climbed to 3000 it shot up(i let off the throttle when it hit just over 5 psi but you could tell it was going to shoot threw the roof if i let it. So im going to run down to PNP and grab some stuff so i can finally mount the cbv and grab some extra piping to run the mbc. Im not sure what kinda of hoses i should use(i know ian said NOT to use the clear stuff) so for now ill mount the mbc on the body close to the turbo and use another wastegate actuator line for the mbc.
 Post subject: wow i feel like an absolute idiot
PostPosted: Mon Oct 02, 2006 6:43 pm
i feel so stupid right now, i tracked down why i was saying my car had no go, one of the injectors wasnt grounding right(on the volvo harness the connection had popped out of the pigtail a bit,
Im praying i havent done any serious damage to the car, it showed no sign of damage but im preparing for the worst. so i put the pigtail together properly and i gotta say, this thing is fast!
Again i pray i havent damaged the engine or anything like that :cry:
PostPosted: Mon Oct 02, 2006 10:28 pm
Don't see how you could have?
your new password is being pm'd to you.
PostPosted: Tue Oct 03, 2006 1:05 am
yea, i duno it seems ok, and runs/performs like a dream. I can't believe the difference from the old b21F
PostPosted: Tue Oct 03, 2006 6:50 pm
I'd like to take a look at this and see your work
PostPosted: Wed Oct 04, 2006 12:53 am
ditto
PostPosted: Wed Oct 04, 2006 7:39 pm
yea for sure, ill have it out at the cruise for sure. Raz, i fixed that hot start issue, just had to change the cranking pulse to a higher value and it worked like a charm.
jonny d
