It is currently Tue May 05, 2026 9:37 am
 Post subject: Tires repair
PostPosted: Sun Oct 15, 2006 11:08 pm
Last friday, I went to the shop with my snow tires. Both had 2 small holes about 5 cm apart. The guy just put a patch and that's it.
Just that? Can I trust that? I didn't seem to be very strong. Anyone have experience with that? One tire, I wouldn't care so much, but two...
PostPosted: Sun Oct 15, 2006 11:52 pm
i wouldn't worry about it... did he patch the inside? or put a plug in it?
PostPosted: Mon Oct 16, 2006 12:01 am
the plugs are strong and they have all sorts of sealant put around them inside. If done properly then you'll be fine.
PostPosted: Mon Oct 16, 2006 12:15 am
while working at kal tire i patched a lot of tires...they do it for free by the way...and yes it will hold up as long as the patch/hole isn't on/near the sidewall, then you may have a pooched tire
PostPosted: Mon Oct 16, 2006 7:15 pm
Yes, it was free. (well, I gave a tip to the guy, but that's all)
he patched the inside. both hole are about 2 inches from the outside wall.
