It is currently Tue May 05, 2026 9:42 am
 Post subject: Hum... What's wrong again?
PostPosted: Tue Nov 07, 2006 11:50 pm
My idle is not really stable and my temperature gauge behave weirdly i.e. : show normal temperature but get a sudden drop before returning to its normal position (only at idle)
Do I have problem with my water pump or a belt or something like that?
PostPosted: Wed Nov 08, 2006 7:12 am
Sounds like a rusted ground. Clean the ground wires at the fuel rail bolts, and clean both ends of the grounds from cam cover to firewall.
PostPosted: Wed Nov 08, 2006 9:05 pm
The what in what where? :oops:
fuel rail bolt? :?:
PostPosted: Wed Nov 08, 2006 10:52 pm
There are 2 10mm bolts that attach the fuel rail to the intake manifold. They both have a multitude of ground wire connections on them. Remove the bolts, clean the terminal connectors up and tighten them back down... Don't miss any ground wires when you put it back together... :wink:
