It is currently Sun Mar 15, 2026 1:42 pm
 Post subject: What do I need to fix that? Another leak...
PostPosted: Wed May 16, 2007 8:33 pm
Minor one, but still. :cry:
(That's the antifreeze tank beside the air filter)
PostPosted: Wed May 16, 2007 11:33 pm
clean it, jb weld it, forget it!
PostPosted: Thu May 17, 2007 7:01 pm
jb weld? :?
PostPosted: Fri May 18, 2007 2:55 am
Its like an epoxy glue
PostPosted: Fri May 18, 2007 6:36 am
It is hard to tell from the picture if the leak is in the plastic tank or just the hose. First thing I would try is simply tightening the hose clamp, if it is in the tank you have a 50/50 chance that something like JB will work, remember it is under pressure and patching a pressurized leak from the outside is never a good fix, the patch should be on the pressure side.
PostPosted: Fri May 18, 2007 11:53 am
if the tank is leaking just get a new one from PNP, but ya its probably the hose or hose clamp
PostPosted: Fri May 18, 2007 1:17 pm
He lives in hinton
