It is currently Sat May 02, 2026 7:57 pm
Post a new topicPost a reply Page 3 of 3   [ 39 posts ]
Go to page Previous  1, 2, 3
PostPosted: Mon Jul 23, 2007 8:10 am
Lots of comments of various Volvo boards regarding creaks and noises from 70 series cars. Most common are upper spring seats, sway bar links, ball joints and control arm bushings
PostPosted: Mon Jul 23, 2007 11:24 am
I can do the pressure wash and undercoating at work, I can just check the car here to be honest one night. That would be easiest.
PostPosted: Mon Jul 23, 2007 5:11 pm
where do you work edicius?
PostPosted: Mon Jul 23, 2007 5:46 pm
Andy is our local Volvo tech, he works at Valentine;-)
PostPosted: Mon Jul 23, 2007 6:34 pm
ah. somehow I'm slow, didn't put together that andy = edicius
I = speshal today.
PostPosted: Tue Jul 24, 2007 8:08 pm
Another option, if it creaks when pushing on it... Would be sway bar bushings.
Links Clunk more than anything. They can squeak if the car is sitting still and you turn the wheel side to side. You can inject grease into the links, prolongs their life.
I've found the rocks in springs cause more of a BOING than a squeak. We get this quite a bit here since our roads are crap.
Another thing, again more of a clunk. Is sometimes the spring will just touch the perch in the front at the bottom. You can see it if this is happening. You'll see the shinny part. Just use a pry bar and bend it out of the way.
BUT, I'm with most other people, probably the upper mounts. They are pretty common.
Also, the front engine mount, directly below the crank pully. They don't last long at all, and not many people bother replacing them. They don't squeak though, more of a vibration.
PostPosted: Tue Jul 24, 2007 9:27 pm
meah well, if someone wants when we do that meeting (cause andy if you're still gibbled, REST YOURSELF! y'all can show me what exactly it is I am looking at (or for)
much love to y'all
PostPosted: Tue Jul 24, 2007 9:49 pm
Heres another good one.
The steering bushing at the firewall for the steering column will squeak when you are turning the wheel. Its an easy fix, pull back the boot and push the little clip down and put a bunch of grease in there and bam, quiet.
Also another squeak are the steering stops, if they are dry then they will make noise but thats only on full lock of the steering wheel.
But i'll be at the meeting, I can figure that one out for ya.
PostPosted: Tue Jul 24, 2007 10:23 pm
hurrah! I am actually looking forward to the shenanaginnery.
