It is currently Fri Mar 20, 2026 8:05 am
 Post subject: Shocks - not electrical ones
PostPosted: Mon Apr 26, 2010 11:25 am
Hi - been reading here for an hour.... I just have a simple question, :mrgreen: and better ask it before I get going: After seeing the pics of Dustin's cross-member with the holes on top spreading-out from the shock, I installed my shocks yesterday. My simple question is: how much to I crank-down the bolts on top and bottom? I'm using bilsteins and I'm told now that they are going to be a little stiff, but I guess I can't help that now.
BTW: I'm putting the bolts back in that were there in the first-place, and they are not grade 8 -I guess the shock should take most of the er.... shock?
I have pics of the car, but can't find the cable to download 'em (yet).
Thanks all.
 Post subject: Re: Shocks - not electrical ones
PostPosted: Mon Apr 26, 2010 1:03 pm
Thanks all.
There is a spec for that in the Bil manual - I've always done it until the bushing is a little squished, but not barreled out. That's enough. The rear's are over valved, the fronts are fine IMHO.
PostPosted: Tue Apr 27, 2010 12:43 pm
Thanks, Craig. and I'll keep an eye on that hole in the top. Actually, I'll be keeping an eye on a lot of things - it would be a shame for something to break because I forgot to tighten-up a bolt somewhere in all those suspension bits....
:arrow: BTW: Did you get brake-lines done-up (where?)
(Surely, I can "jack" my own thread)
J
PostPosted: Tue Apr 27, 2010 8:44 pm
I've got IPD stainless brake lines on the car - the hard lines I did myself (where required). There was a guy on the Brickboard when I use to hang out over there, that had the clutch cable done in stainless - so I bought one. His name is Chris Horn. I'm sure Matt and Dale could have one made in Calgary for you. This was a great upgrade.
PostPosted: Tue Apr 27, 2010 10:14 pm
Hi Craig, and anyone-else who is reading.
Ok. I'm not sure if by SS brake lines you mean you bought actual tubing, or hoses covered with braided stainless. I'm asking because I had some of the latter made at Green Line, and the ends that go into the block do not rotate independently of the hose. Also, they are fatter - so fat, I would have to shim-out my brake block.... And they don't seem to thread-in more than 1 1/2 turns! All-in-all, I am going to have to return them, and need to know what other options there are. I asked about it when I picked them up, and the fellow said those ends were all they had. I realise now, I should not have taken them, but.....
They are pricey, but I can't see putting in anything less (I broke one when taking-off the front gear). I'm not thinking there is any improvement per se, but you say they are a great upgrade, what do you mean by that??
Thank -u!
James
