It is currently Sat Mar 14, 2026 8:25 pm
 Post subject: 760 t5 swap
PostPosted: Tue Feb 17, 2009 4:52 pm
well, it looks like my tranny is on it's last legs in the 760, so... i happen to have dale's awesome adapter, and a WC t5... with a hole punched in the case... shit... but a WC t5 if i can get another case to swap the guts into.... I was just wondering, what needed to be done as far as the shifter relocation into a 7 series? and the pedals? I know someone on here has done it... I think... I am searching Tbrix as I type this... And using excessive amounts of ellipses...
PostPosted: Tue Feb 17, 2009 9:51 pm
Was Ian's car an auto? He's got a T5 behind the 302.
PostPosted: Wed Feb 18, 2009 7:47 am
Yes mine was an auto and converted to the WC-T5 behind the 302.
You will need the clutch and brake pedal assembly, all the mounting locations and holes are there. I used a cable clutch, but you have the option of using hydraulic also.
Shifter location on my application was about 2"-3" forward, which required cutting the floor and fabricating a very "interesting" shift lever, but it works extremely well (ask Craig, Dale & Matt, they have all driven my car) here are some pictures:
PostPosted: Wed Feb 18, 2009 10:01 am
It sure does work well...as does the entire car.
PostPosted: Wed Feb 18, 2009 9:47 pm
wow, how on earth did you make that shift lever? I guess I could just break out the oxytorch and a turbocoupe one and bend it up... but still!
PostPosted: Thu Feb 19, 2009 7:19 am
The shift lever is a B&M Ripper Shifter and heat and bend is exactly what I did. To clear the center console and to locate the shifter to the correct position I bent the lever into a very aggressive "S" which is actually entirely below the console. Then I fabricated an extension that is about 4"-5" long that threads onto the top of the shifter lever, the shift knob is then mounted on top of the extension.
PostPosted: Thu Feb 19, 2009 11:43 am
Verrry interesting... is your T5 close to where it would be, behind a redblock?
PostPosted: Thu Feb 19, 2009 1:58 pm
It should be close. I say this 'cause the V8/T5 in my 240 lined up perfectly with the shifter hole, and the T5 behind a redblock lines up perfectly in a 240 as well. Therefore it stands to reason that the shifter in Ian's 700 is pretty darn close to where you'd expect to find it behind a redblock.
I'll be finding this out shortly, for myself.
