It is currently Mon Jan 19, 2026 8:37 pm
Post a new topicPost a reply Page 7 of 28   [ 407 posts ]
Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 28  Next
PostPosted: Wed Nov 04, 2009 6:57 pm
paperjam wrote:
Its the rule of three.
one primary, one secondary, and one accent. You dont want your colors competing for attention too much. If you will notice on the mustang that the Grey secondary color is very similar in shade and tone to the blue of the rest of the car. try to keep your color similar (at least in tone) to ensure it wont look gaudy. its ok for pinstripes to be loud, as they are so small.
I'm with you there Alex...the third colour is the black stripe/trim.
PostPosted: Wed Nov 04, 2009 7:26 pm
OK - on with the bodywork...I'm very happy to announce that the white car is going to be derusted and straightened starting now. GO. For those that have never seen the car, the clear had peeled and some idiot had painted over it giving it less prep than I would my fence. It is horrific.
So the first order of business was to lift some panels from Matt's collection. He was more than happy to donate to the cause as there seemed to be a garden of panels to select from - all different colours sprouting up around his yard. I chose the green one and two red ones.
I thought the green one was going to be a winner as it was very shiny and looked like it had been well cared for - only one small dent was visible. Magic, I thought.
So I get the parts home and let them season for about a year (no sense rushing into things). The other day while waiting for my furnace to be installed, I decided to derust the panels and weld up the trim holes.
It goes something like this.
First, you can't weld over paint, rust, goo from the factory, or any other crap - so I cleaned the green fender and a red fender (the other red fender was painted blue for a test).
Clean the backsides with a heat gun to get the undercoating off and then wash with thinner or hit it with a surfacing disk. This is just before washing and prepping with the surfacing disk. A heat gun does work on this stuff - skinks though.
Then using a heat sink (copper pipe flattened in vice) weld up the holes from the BACK side using the sink against the front side of the panel. Keep the heat down (using 0.023 wire lowest heat) and make nice little welds. Take your time as you don't want to warp the heck out of the panel.
Done.
Front side - oops forgot to clean all the paint off the front.
This is much less work to fill in the end compared to welding on the front side. The heat sink makes the spot almost level as the heat is directed away from the sheet metal into the sink (making it hard to hold :lol: ).
Now - inspect the panel - look for dents (some are obvious like this one, some need to be found).
These have to be taken out with hammer and dolly work - no filler until you can't get it straighter. This dent is around 5 mm deep and was enough to stretch the panel (when I beat it out - the panel was flexible like an oil can). This then required shrinking (don't fill oil-canned sheet metal, it will just pop off). The technique involves either a shrinking disk or a torch. I opted for the torch this time as it was handy. Just heat the spot a little at a time (not red hot) and quench it with water. This shrinks the metal back to it's original shape. It takes some practice, but don't stop until you get the panel to the point that it is fully tensioned again. Took about 20 minutes - no pictures I was holding a torch for heaven's sake!
Look for other nasties - rusted bolts (there were 2). They look impossible to remove - but grind them clean on the back side and then weld on a bolt. Like so.
The heat helps - then just wind it out when hot.
Chase the holes with a tap (oil them up in advance) - this cleans out the rust.
Last but not least - take the fender out to be blasted clean of surface rust. The green fender didn't survive. A little surface rust ended up being not worth repairing as I was able to blast right through. Then I was stuck with the panel that I had painted 2 coats of paint on as a test.
Wash off fresh paint with lacquer thinner - weld holes first...go into house with solvent buzzzzzzzz :mrgreen:
Done - (note dents removed).
Before.
After an hour with the thinner...
PostPosted: Wed Nov 04, 2009 7:55 pm
So THAT'S how you weld up trim holes! Brilliant! =D>
PostPosted: Wed Nov 04, 2009 11:15 pm
I'm starting to get excited for this. Sweet!
PostPosted: Wed Nov 04, 2009 11:52 pm
glad I saw this BEFORE I attempt to weld up mine...
PostPosted: Thu Nov 05, 2009 6:02 pm
Another day waiting around for the inspector to come and pass the heating and electrical. He was a no show again! Anyway, it was very warm in Southern Alberta today so I decided to sandblast the fenders and get them in some epoxy primer. I've never used the pressure blaster so this was a learning experience. I started by putting down a single tarp (I'm an optimist :roll: ) and lining every thing up that I needed.
I bought some copper slag blasting media - this turned out to be a mistake. Anyway, I fiddled around with the various ball valves and managed to turn this...
into...
First try - changed to a less coarse blast media (works better).
Done.
I then treated the panels to some Metal Ready (they rust very quickly) - and got ready to shoot. I didn't bother feathering things out - I've got filling and some more masaging to do still. This is just a "get it covered" coat for the front and I'm going to shoot the back sides with whatever I've got after I seam seal it - then undercoat.
Here we are almost ready to shoot - still have to clear some stuff out of the way and put up the final drape.
Here they are done.
Now to get some paint on them tomorrow and get them undercoated.
PostPosted: Thu Nov 05, 2009 11:08 pm
Very nice.
PostPosted: Sat Nov 07, 2009 6:43 pm
Today Greg swung by and we got going on stripping the car (well Greg did most of the heavy lifting). The car is actually remarkably solid underneath and the rust is limited to the usual places with the exception of the rust around the windshield which is pretty bad. We met in the AM and developed a game plan and pulled all the trim off the car. I then took it to the car wash for a good going over and a wash with Comet to clean off the wax and other contaminants.
Greg then got to work doing what he does best and I started hacking out the rust.
The rear butt cheek areas are not bad and the inner parts are solid.
I got to work on the replacement panels...hmmm, these need some shrinking.
Ah, that's better.
End of the day - no more front end.
No more rear end.
There are still some parts to strip off the car and put away, then I've got to get the rear end welded up, a little sandblasting and we decided that changing out the suspension at this point is probably easiest. So we'll have to swing by Greg's garage and pull the struts out of his car to put in mine and get the strut tubes blasted and fixed up before the fenders go back on.
No time lines yet, but we'll just keep on plugging.
PostPosted: Sat Nov 07, 2009 7:05 pm
i'm curious, how do you shrink the edge of the panel like that that's just been crimped?
PostPosted: Sat Nov 07, 2009 7:46 pm
Shrinking metal requires a soft hammer backed up by either a metal dolly or a block of wood. It's pretty easy as they have already "gathered" the metal for you. I could have made that perfect, but I didn't go too far as it is a fender seam - here's a shot of the finished edge seen edge on.
Remember, metal hammer and dolly stretch while a urethane hammer and wood will shrink (if gathered), if not then you have to either gather it yourself or use heat. I've seen lot of people bashing away on a panel with a hammer and dolly and they just stretch the heck out of things, sheet metal is only a few thou thick and doesn't require hammer blows that come form your shoulder or smashing over an anvil.
PostPosted: Sat Nov 07, 2009 9:34 pm
so are you getting it hot at all to try and "push" the metal sorta to get thicker with the poly/wood?
PostPosted: Sat Nov 07, 2009 9:56 pm
No heat - cold forging.
PostPosted: Sat Nov 07, 2009 10:22 pm
so then the metal actually gets "thicker" more or less? i think i'm gonna try that on the 220 rockers when i get around to it.
PostPosted: Sat Nov 07, 2009 10:47 pm
Interesting start - I'm looking forward to the updates! :)
What happens when it gets cold?
Brings back memories for me... :lol:
( http://s41.photobucket.com/albums/e279/ ... usDiaries/ )
PostPosted: Sat Nov 07, 2009 11:32 pm
is that the blue wagon that sits at the college?
1970 Mercedes 220D
1971 Daimler ds420
1977 Mercedes 230
1979 Mercedes 300TD
1993 Honda Del Sol Si
1994 Honda Civic dx hatch
2015 Mazda CX-5
2020 Hyundai Elantra manual
1982 240 DL coupe
