It is currently Fri Mar 20, 2026 6:45 am
Post a new topicPost a reply Page 5 of 6   [ 88 posts ]
 Post subject: Re: Guess the Tool
PostPosted: Mon Apr 19, 2010 4:14 pm
I suspect twin Webers?
That was my guess - carb balancing tool.
Ya'all are on the right track but not close enough yet
Matt, I can understand why you would have one :wink:
PostPosted: Tue Apr 20, 2010 7:12 pm
is it something V8 specific?
PostPosted: Tue Apr 20, 2010 8:11 pm
Nope, used on 4, 6 & 8
PostPosted: Tue Apr 20, 2010 9:11 pm
Something to do with dwell?
PostPosted: Wed Apr 21, 2010 6:41 am
nope
PostPosted: Wed Apr 21, 2010 10:46 pm
well i checked all my known sources....I am out #-o
PostPosted: Thu Apr 22, 2010 4:17 pm
Tha VZA wrote:
IT'S A JOHNSON ROD!!!
Urban Dictionary ....
3. johnson rod
device that is connected to a gazach via a knibbling pin
the johnson rod fell from the gazach because the knibbing pin fell out.
Is that like when you have a torqued out spindlewhammer dappled with a sludge pump ? (I can't remember what TV commercial that came from. Canadian Tire Service ?)
PostPosted: Thu Apr 22, 2010 4:44 pm
That was a vindelrotor, not a spindlewhammer... #-o
PostPosted: Fri Apr 23, 2010 6:57 am
Some of you were very close on this tool.
It is a carburetor adjust tool.
In the early to mid 1980's just prior to basic EFI being introduced the idle adjustment screw was recessed into the front casting of the carb and sealed with a steel plug (early solution to emmisions). To adjust the carb idle circuit (which needed to be done because the factory adjustment was so lean that many cars would not even idle, let alone idle smoothly) the seal plug was removed by breaking away part of the lower casting, then this tool would engage the idle mixture scew making it adjustable
PostPosted: Sat Apr 24, 2010 12:46 pm
should be an easy one
PostPosted: Sun Apr 25, 2010 9:08 am
Did you and Craig have the same photography instructor :lol:
This tool is for automotive use, correct? (think I know what it is for?)
PostPosted: Sun Apr 25, 2010 11:23 am
Spark plugs on the end of a long rod with flat plates. Looks to me like a tool you might use to take the valve cover off a 5 or 6 cyl whiteblock.
PostPosted: Sun Apr 25, 2010 12:03 pm
Volvord, yes, and Edicius, you're mighty close.
PostPosted: Sun Apr 25, 2010 12:26 pm
I figure it's for pulling the head, not the valve cover...4, 5 or 6 cyl DOHC heads...
PostPosted: Sun Apr 25, 2010 4:29 pm
My guess too, but Dale wins the prize =D>
