It is currently Fri Mar 20, 2026 9:51 am
Post a new topicPost a reply Page 11 of 25   [ 363 posts ]
Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 25  Next
PostPosted: Sat Aug 14, 2010 9:12 pm
my goofy trailing arm plan using an energy suspension 9.9489 bushing.
PostPosted: Sun Aug 15, 2010 11:07 am
an idea for mounting the radiatior...
and the cross-bar between the frame rails... seems to have been in an accident sometime eh?
ah well, makes it easier to cut out/replace i guess.
any comments? ideas? this doesn't seem ideal to me.
PostPosted: Sun Aug 15, 2010 11:51 am
Take a look...
http://s377.photobucket.com/albums/oo21 ... ?start=all
I can pretty much predict what your next post/problem will be... :wink:
PostPosted: Sun Aug 15, 2010 1:17 pm
haha nice! Looks like what i'm going to need to do!
i guess i'll move it as far back as i can towards the engine and see what i can fit in front of it...
I did also find some rust underneath where the tailgate is in the bottom corners so that will need to be taken care of too.
fitted a b230 intake... looks like it'll be a bit of a PITA because a bolt on the bottom TB block-off plate will hit the steering column. so i'm gonna toss it in the bbq after cleaning it and braze it on next weekend i'm down (2 weeks?)
Dare i ask what my next problem will be?
PostPosted: Tue Aug 17, 2010 8:34 pm
They're only problems if you think of the short-term. Just think next 'step.'
I-know, easier said than done, but remember: you WANT to do this right!! Hahhahah
J
PostPosted: Wed Aug 18, 2010 6:58 am
wouldn't a kjet intake fit better?
PostPosted: Wed Aug 18, 2010 7:35 am
Doesn't look like it to me, Athal - the plenum would whomp the master cylinders. I think an old school B21FT intake might work though - points the throttle body in the right direction, anyway. Modify the K-jet holes to take LH injectors like I've done a few times, and you're set.
PostPosted: Wed Aug 18, 2010 11:06 am
ah, this head has k-jet holed jb welded with pennys/nickels in it :(
a b21ft intake i reckon would work the best.
Matt, do you have any info on mounting a fuel rail in the injector holes? it didn't seem to line up for me when i tried, and figuring out a mounting setup seemed fairly impossible.
I'm going to hole-saw a 3" hole in this manifold, braze in a tube, and braze a TB flange on said tube.
PostPosted: Wed Aug 18, 2010 12:04 pm
Done it a couple times!
Rail from the backside:
And my high-tech modification to the K-jet injector bung:
Drill to halfway through the original injector seal recess, and you're set.
PostPosted: Wed Aug 18, 2010 12:57 pm
Hot damn! That makes sense now, I never tried using the injector bungs....
If I still have that spare 405 kjet head.... Hmm
PostPosted: Wed Aug 18, 2010 1:40 pm
Dale has that fuel rail set up with the motor i sold him. Not sure if hes using it or not...
PostPosted: Thu Aug 19, 2010 5:09 pm
I am not using it. I am also not using most of the LH 2.2 sensors that came with the engine. If you need anything, let me know...
PostPosted: Thu Aug 19, 2010 5:46 pm
ordered paint supplies today, gonna play with some of the paintwithpearl.com stuff i've used before (with good results!)
let me spray a couple test panels before i decide on a colour, but expect somthing in the next 3-4 weeks as soon as i find a good cheaper black base coat. let's just say i'm going to try my hands at a lemon-lime chameleon colour with some flake, some whacky stuff, otherwise i've picked up some electric blue as a standby.
I use a fairly cheap (~~$80/gal) clearcoat as a base for the pearls and then will probably cover everything in a nice clearcoat when done. wish i could dig up some pics of the last bike i painted.
Dale: Thanks in advance, i'm going to dig through everything and see what i can come up with before i start bugging anyone too badly for parts, i figure if the b230 intake will work, i should use it. One thing i need to find is a 3" 960 throttle body.
i've spent ~~6k on everything so far, and probably have another 2-3 to go :S
PostPosted: Thu Aug 19, 2010 6:17 pm
I've got a B21FT intake as well, if you think that might work. I've got 3 960 throttle bodies. Unfortunately 2 of them are on cars currently being used and the other is on the intake Matt built for my B234 going in the 122. :wink:
PostPosted: Thu Aug 19, 2010 6:38 pm
haha darn! pics of the intake?!?!?!
I'm hoping to have this driveable soon enough to take a quick trip to calgary and come see y'all.
so who would i talk to for an 60-2 tone ring on a crank gear? then i could use lh 2.4....
