It is currently Fri Mar 20, 2026 10:13 am
Post a new topicPost a reply Page 13 of 25   [ 363 posts ]
Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 25  Next
PostPosted: Wed Aug 25, 2010 9:52 am
ordered bushings today, so my trailing arm design is finalized. new pucks are here for jigging the rear end properly. The only catch now is i've gotta fill that 1/8" gap that is left behind from the saw blade. So, i should have a rear axle mounted this weekend.
also ordered a b21/23 edis adapter. I'm planning on picking up my LH harness from the acerage this weekend too.
Also, i've decided to remount the engine, probably a half inch higher or so than it was, that will give me all the clearance i need. I'll hang it between the frame rails like the PV. I may need to clearance the d/s tunnel though.
PostPosted: Fri Aug 27, 2010 12:48 pm
sweet. got the rear end cut down again, one of them right through my old weld... looks solid! i wish i had a digicam instead of the blackberry or else i'd be able to take a good picture.
PostPosted: Sat Aug 28, 2010 8:36 pm
got busy with Sol/folks today, so only managed to pull a 240 lh2.4 wiring harness from the acerage i had stashed away and got a fuel pump from a 760. I'm going to try running only the main pump for the time being, and replace with a walbro/whatever when it starts to burn out.
PostPosted: Thu Sep 02, 2010 6:22 am
got a phone call from the 'rents, apparently there's some "Pulley type thing" and some "Bag of round rubber things with metal tubes" that cam in the mail for me :) but no paint stuff yet.
Should be able to get the axle all mounted up this weekend. Unfortunately, i do have to replace the two pinion bearings :( (due to my own clumsiness) BUT since i'm not changing anything, i should be able to get away with using the same shim pack, etc, less any differences in the bearings themselves.
This will also give me a chance to swap to a smaller mustang style flange (the explorer is 3.5") and save me some headaches with clearance.
I hope to fire the motor up by the end of next week.
As well, this is my second last day in fort mcmurray..... ever.... and i'll be back at school for 8 months.
PostPosted: Mon Sep 06, 2010 7:45 pm
couldn't get any DOM pipe for my mounts yet, so i started running a wiring harness and building my intake....
PostPosted: Mon Sep 06, 2010 9:06 pm
Are you JB welding that mandrel in there?
PostPosted: Mon Sep 06, 2010 10:06 pm
Brazing with oxyfuel. I also am going to make some bolt-on bracing too as it is going to have some nasty vibrational stresses.
PostPosted: Mon Sep 06, 2010 10:36 pm
Why not get an aluminum mandrel and weld it properly...I can't see brazing working very well.
PostPosted: Mon Sep 06, 2010 11:36 pm
Mostly lack of skill. This is an interim thing until I learn tig welding. Plus, the bov flanges and stuff I've done like this have held awesomely. As well as the end tank on the kenworth ic.
PostPosted: Tue Sep 07, 2010 12:10 am
I spy a V8 Mercedes throttle body?
PostPosted: Tue Sep 07, 2010 7:14 am
Looks a bit BMW'ish to me...
PostPosted: Tue Sep 07, 2010 9:30 am
82' 733CSI ;)
also, 17x12x3" w/ 3" in/out i/c, 3" 960 amm (for later).... should have no intake restrictions....
PostPosted: Tue Sep 07, 2010 10:52 am
guess i should add that this is the TB with a progressive linkage, as well, i pulled a 740 turbo throttle pedal, it looks like it'll work great.
got my bushing bits, so i'm making the trailing arms this morning.
PostPosted: Tue Sep 07, 2010 12:56 pm
tacked it up, gotta weld the plates onto the 8.8" and then will bolt it up.
PostPosted: Tue Sep 07, 2010 1:09 pm
Oh well, I have one of each (somewhere) and I knew it looked familiar.
Users browsing this forum: Google [Bot] and 2 guests
